Battery level indicator?
This is a discussion on Battery level indicator? within the iPad General Discussions forums, part of the Apple iPad Discussions category; How many charge cycles does it usually take before the battery level indicator is actually accurate at estimating battery level? Also, when doing a battery ...
Results 1 to 10 of 17
    iPad Junkie!
    4520
    May 2010
    111
    How many charge cycles does it usually take before the battery level indicator is actually accurate at estimating battery level? Also, when doing a battery cycle, do they mean fully letting the iPad battery die and then recharge it to full battery or just to use it normally and just recharge it a few times once I'm done using it?
    Off-topic: I'm loving the iPad keyboard... It's very very accurate and responsive and I can type on it at a rate almost that of how fast I can type on a physical keyboard... But I do make a mistake every one in a while.
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    Didn't know it was inaccurate, but then I've never fully drained it.
    Given the long battery life I'm quite happy to accept it as a rough estimate and only bother recharging around 20%, unless I'm anticipating heavy usage at some stage.
    iPad Junkie!
    4520
    May 2010
    111
    Quote Originally Posted by Hasty View Post
    Well, it I'd pretty accurate, but when I first received my iPad and took it out of its box, I turned it on and played with it a bit and the battery level indicator was going down 1% every 5-10 minutes, but after letting it charge overnight it seems to have calibrated a bit mire and it seems to be more accurate... This could have been just because I instantly started using it the second I took it out of the box, but all seems well now.
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    ..... I instantly started using it the second I took it out of the box......
    Lol didn't we all!
    Glad it's settled down though. You've probably got a frisky one.....
    9587
    Jul 2010
    Lisbon, Portugal
    6
    I wonder why mine has a little message 'battery not charging' when it's connected to the Mac but charges when connected to the power adapter?
    I wasn't aware that it was necc to deplete the battery completely before recharging but then one would have to connect it to a Mac to do sync -yes?
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Quote Originally Posted by abriwin View Post
    Wonder no more! There is a handy little document called the iPad User Guide that is a free .pdf download in the support section of the Apple web site.
    Here is a snippet from the guide:
    As far as the not charging message, this is what you will see when you plug your iPad into a computer's USB port. It is actually charging, but verrrrrrrry slowly.
    Here is a link to the page where you can download the iPad User Guide.
    http://support.apple.com/manuals/#ipad
    It is 154 pages long so it will take a few minutes. After you download it, save it so you don't have to download it every time you want to look at it. Also, there is a bookmark in Safari on your iPad with a link to the online iPad User Guide.
    Lots of good stuff in there!
    6873
    Jun 2010
    Melbourne, Australia
    11
    My iPad only charges to 95% it never goes to 100%. I'm not sure why. I have drained the battery a few times and when I charge it (usually overnight) the battery only charges to 95%.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Quote Originally Posted by Eatosk View Post
    Well now that's just bizarre. Are you charging it with the stand-alone charger or the USB port on a computer?
    9587
    Jul 2010
    Lisbon, Portugal
    6
    to charge or not to charge that is the question
    Many thanks to iPad Master for the most complete answer to my question
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Você é bem-vindo!
    Apple has User Guides for many of its products in Portuguese, but unfortunately they do not have one for the iPad yet. They do have a Spanish version of the iPad manual. Obviously you seem to know English very well, but they do have the User Guide for the iPod Touch in Portuguese and that might help since the iPad and the iPod Touch share many similar features.
  1. WiFi Indicator missing after JB.
    By kilofox in forum iPad Hacking
    Last Post: 12-09-2012, 11:07 AM
  2. multi level hierarchial tree style lists
    By omro in forum iPad Apps
    Last Post: 06-05-2010, 04:10 PM
  3. 3G Battery Life
    By msskarina in forum iPad General Discussions
    Last Post: 05-02-2010, 08:12 AM
  4. I just got my 2nd battery
    By Sincere11105 in forum Off-Topic
    Last Post: 05-01-2010, 07:57 PM
  5. iPad Entry Level Point of Sales System For Food Services
    Last Post: 04-27-2010, 03:12 PM
battery life indicator on i pad
battery status for ipad
check battery status ipad
how do you check battery amount on ipad ?
ipad battery level indicator
ipad charges to 95
ipad charging indicator
ipad charging to 95
ipad only charges to 95
ipod only charges to 95 percent
my ipad only goes to 95%
whwere is the indicator that the ipad is charging
