iPad as Turn by Turn car gps & music storage device...
This is a discussion on iPad as Turn by Turn car gps & music storage device... within the iPad General Discussions forums, part of the Apple iPad Discussions category; So ive been toying with the idea of getting an iPad 1 to use as a turn by turn gps and music storage device in ...
Results 1 to 4 of 4
    103264
    Sep 2011
    Louisville, Ky
    So ive been toying with the idea of getting an iPad 1 to use as a turn by turn gps and music storage device in my car... but do not plan on subscribing to a 3G plan for the ipad. Ive heard a little bit about bluetooth gps antenna's available to turn wifi only ipads into a tomtom type gps and was wondering if anyone has any experience with this. Space isnt a big issue, i drive an F350 so i have plenty of room.
    37823
    479 times
    Cranbrook, Kent, UK
    15,265
    You can get a 3G iPad without subscribing to a 3G plan, so if you want GPS functionality then that may be the best way to go (as GPS is only included on the 3G iPads).
    61094
    6 times
    Jun 2011
    271
    I used Navfree California in the rental car in a recent trip to the SF Bay area. It worked as well as the TomTom I have in my own car. I also use Navfree Australia from time to time of my motorcycle more as a map than a device for directions and it works as well as any of the dedicated motorcycle GPS units that my friends have. It has a lot of advantages over those units as well.
    40617
    2 times
    Homeless
    198
    Yes at this time there are three units out there, all three of them cost about 100.00 each and they can be found on Amazon.com. All three units work and work well. I'm a pilot and have used each of them and know people that use them as well.
    Note all of them are WAAS enabled GPS receivers.
    1. Bad Elf - This unit is different from the others as it plugs into the Ipad in the interfact/charge port. This means you don't have to charge it as it gets it power from the ipads battery. However as it attaches to the Ipad this may be a problem with most ipad mounts out there. Also it is easy to bump the unit and disconnect it. There has been a worry about bumping it and damaging the port but I have not heard of that ever happening.
    2. GNS5870 - This is a small little blackbox GPS receiver. It has it's own battery that you have to remember to change and it interfaces with the Ipad by bluetooth. The only down side to this little guy is the one and off switch can be a pain in the butt untill you get use to it. Only work works with Apple products.
    3. XGPS150 - Like the GNS 5870 this is a small battery power unit that needs to be rechanged. This one not only works with you apple products, but it would work with android or other PC's unlike the other two. You also get a couple of nice mounting options with this unit as well.
    The XGPS150 is the unit that I tell people to get.
    Rudy Ackerman
    Currently on the road and homeless
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
  1. Can i turn my iPad 2 into a Hotspot Device?
    By kingsleyfhk in forum iPad Carriers
    Last Post: 07-26-2011, 04:26 AM
  2. Best network storage device to use with iPad except Air....
    By Kezug in forum iPad General Discussions
    Last Post: 03-27-2011, 09:24 PM
  3. Can't turn Ipad on
    By cyprus203 in forum iPad General Discussions
    Last Post: 03-07-2011, 09:46 AM
  4. Replies: 21
    Last Post: 11-02-2010, 12:22 PM
  5. Replies: 7
    Last Post: 06-03-2010, 03:34 AM
car music storage
how to turn the sound on, on the gps on ipad
ipad as car gps
ipad as gps in car
ipad car gps and music
ipad gps antenna
ipad gps voice tunr
ipad music car gps
turning ipad into gps
turning your ipad in to car gps
using ipad as a gps in car
using ipad as gps in car
