Better to charge more often or to let your battery get really low before you charge?
This is a discussion on Better to charge more often or to let your battery get really low before you charge? within the iPad General Discussions forums, part of the Apple iPad Discussions category; If there was a thread about this, I apologize. I'm on this site daily and check the active topics and didn't find it. But I ...
Results 1 to 10 of 16
    90362
    28 times
    Aug 2011
    Milwaukee, WI
    960
    But I was wondering, since the battery life is based on charge cycles, if it is better to charge your iPad daily or to wait until the battery is pretty drained (>20%) before you plug it in? I told my mom, who has an iPhone, that it's probably better to drain it bc the battery is based on charge cycles, but my brother who is probably more tech savvy than me told her she should charge it at the end of the day regardless of her battery level.
    I obviously want my iPad to last me as long as possible so I'm wondering if it makes a difference which approach you take to charging, and which is the better option.
    116 times
    15,249
    Here's the official word...
    Apple - Batteries - iPad
    81168
    Jul 2011
    152
    I feel like I get longer battery life if I let it drain completely before charging it.
    Sent from my iPad 2 using iPF
    76120
    Jul 2011
    Fairfield County CT
    34
    I let mine run down to below 10% before charging. I bought a battery maintenance app called battery magic that supposed to recycle the battery and charge it. I've only charged my iPad twice since buying it so I'm not to sure if I'm seeing any benefit from it yet
    38516
    18 times
    Seattle
    555
    I usually let mine get down to the low teens or 10% then put it on the charger. I try to avoid leaving it on the charger over night, instead do it during the day and check on it about once an hour or so.
    iPad 2 64GB Wifi 5.1.1 jailbroken
    19947
    Nov 2010
    361
    Quote Originally Posted by Wookiee2cu
    This is good advice
    Once a month or so it's good practice to let it drain to 0% and then charge to 100%.
    iPad 2 Owner
    78873
    4 times
    Jul 2011
    316
    Drain to zero? Not an easy thing to plan. I hate having a low battery when I want to use the iPad. Is there a way to run the battery down while not using it and then charge it again? There aught to be an app for that!
    90362
    28 times
    Aug 2011
    Milwaukee, WI
    960
    I didn't mean drain to zero, lol. Just drain low enough. Thanks for the responses, everyone, you affirmed what I thought. Though I have charged mine overnight before - I won't do that anymore.
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    Quote Originally Posted by GoPackGo
    I charge mine overnight, every night with no noticeable drop in performance.
    I started using it at 6:30am this morning and now, some seven hours later it is at exactly 33% which is spot on what a new one is supposed to do (I bought mine back in February).
    iPad Ninja
    62473
    62 times
    Jun 2011
    1,607
    It does not hurt to leave your iPad charging overnight. The charging circuitry is smart enough to stop drawing power once it's no longer needed.
    The full drain simply allows the battery meter to be more accurate when it displays info about the battery.
    Your battery will last the same number of full discharges and recharges regardless.
    -t
  1. can i let my battery charge go to zero?
    By 88raymond in forum iPad FAQ
    Last Post: 08-14-2011, 09:02 AM
  2. Drain and Then Re-Charge Battery?
    By mtrplato in forum iPad FAQ
    Last Post: 08-01-2011, 05:57 PM
  3. Battery app - hours per charge
    By Harters in forum iPad Apps
    Last Post: 05-07-2011, 03:28 AM
  4. Battery-when to charge?
    By CMFox in forum iPad Help
    Last Post: 06-22-2010, 09:24 AM
  5. Initial battery Charge?
    By Ellie in forum iPad General Discussions
    Last Post: 04-02-2010, 08:39 PM
can i recharge my ipad before low battery show
charging an iphone5 before the battery is way low
how low to let i pad go before charging
how often should i charge my iphone 5
how often should ipad battery be charged
how often to charge ipad
how often to charge ipad 2 battery
ipad 2 how frequent to charge
is it better to charge ipad often
should i wait until battery is low to chsrge
should you wait to charge iphone until battery is low
wait for battery to die before charging ipad
