Dvd on ipad need help
This is a discussion on Dvd on ipad need help within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hi please can you guys help, as when I try to put a DVD on the iPad from iTunes it keeps asking if I would ...
Results 1 to 10 of 11
    89487
    Aug 2011
    29
    Hi please can you guys help, as when I try to put a DVD on the iPad from iTunes it keeps asking if I would like to remove 8 apps if I say yes it will remove them then put the DVD on. Please how do I stop this. Thanks for reading Martin
    119 times
    15,248
    Are you using the same PC to synchronise the iPad and transfer the DVD? If the PC you're using is synchronised to another iPad/iPhone etc then this might cause the problem.
    89487
    Aug 2011
    29
    Hi Tim thanks for the reply, I am using my home pc it's only used with this iPad. It is doing it every time I put a DVD on.
    85789
    15 times
    Aug 2011
    Uk
    181
    Avoid this by just dragging your DVD over to the iPad and don't try to do it through the sync tabs along the top of iTunes. I manually manage movies and music this way as I find it a lot less hassle.
    89487
    Aug 2011
    29
    Quote Originally Posted by Jockscrap
    Hi thanks for that, I will give it ago in a bit & report back. All the best Martin
    89487
    Aug 2011
    29
    Hi just had ago but can not do it can you tell me what to do as I am new to all this thanks.
    89487
    Aug 2011
    29
    Quote Originally Posted by glaze77
    Hi again I have tried to drag it over but it does not go on the iPad let me know what you think thanks again Martin
    85789
    15 times
    Aug 2011
    Uk
    181
    Hmmm....not sure. Does it come up with any message? I've had a message before saying the film will not be added as it will not play on an iPod, ie, in the wrong format. When i rejigged the film format, the copying over happened perfectly. I've never had a problem with copying to an ipad though. When you say a DVD, do you mean a digital copy of a film? Was it downloaded from itunes? When I add digital movies from my iTunes library to my iPad, I drag them from the library list in the main part of the screen, over to the iPad list on the left. As I drag it over, the iPad list changes colour and a '+' appears as it gets added. I wonder if it is the format it doesn't like.
    89487
    Aug 2011
    29
    Hi thanks for the reply's, I have one got it going the way you said & yes it is so much easier thanks again Martin.
    94252
    Sep 2011
    Greensboro, NC
    37
    Huh?
    Sorry if this is off topic, but are you saying you can drag a DVD into iTunes and it will put the movie on your iPad???
