GPS away from Wifi?
This is a discussion on GPS away from Wifi? within the iPad General Discussions forums, part of the Apple iPad Discussions category; Can't seem to find an answer anywhere. When I'm away from Wifi, is the GPS supposed to work on my 3G iPad without my having ...
Results 1 to 10 of 10
    4326
    May 2010
    Indiana
    GPS away from Wifi?
    Can't seem to find an answer anywhere. When I'm away from Wifi, is the GPS supposed to work on my 3G iPad without my having purchased a month's data plan? Or do I have to have a 250MB or an Unlimited to have any GPS functionality?
    3532
    May 2010
    52
    The GPS in the 3G ipad does NOT need the 3G account to be active. The GPS in the ipad functions as a standalone unit. This has been discussed to death in several threads.
    4247
    May 2010
    NYC
    5
    GPS is only dependent on 3G for an initial fix to make it faster to acquire the satellites. That's what assisted GPS is all about. WiFi performs this as well. However the GPS will work without the 3G service. It will probably take longer to acquire the satellites the first time since there is no initial reference to help the GPS find the closest satellites. Hope this helps.
    Alex
    4326
    May 2010
    Indiana
    Thank you Aburman. Sorry to trouble you Star56
    iPad Junkie!
    5322
    May 2010
    Newmarket, ON
    104
    While GPS will work and find your location without Wifi or 3G, keep in mind that you need to use data to load the maps - unless you're using an application that stores them locally such as TomTom, etc. or iNavX for example with marine navigation.
    The Maps application on iPad (Google Maps) does not store them locally and depends on a data connection to load them.
    This message was posted from my iPad Wi-Fi + 3G 64GB device.
    4247
    May 2010
    NYC
    5
    You can use Motion X GPS HD which allows you to store an unlimited number of map sections. It is a low cost app, $2.99. Very useful for traveling outside the US since maps are stored.
    Alex
    iPad Ninja
    3495
    27 times
    May 2010
    Switzerland
    2,017
    Just to pile on, I tested my iPhone navigational apps, and can confirm that everything is working without an active 3G SIM installed.
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    The GPS works without a cellular connection, it has a dedicated GPS chip in the device. However apps like the google maps app all though will know what your current location is, it wont be able to show you on the map because that app downloads the maps in realtime.
    a navigation or map app that has all the maps saved on the device will fully work when disconnected from the internet. Navigon and MotionX HD are an example of some that actualy store the maps on your device.
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    I thought the iPad didn't have a dedicated GPS, that it only uses WiFi/3G towers to point to your location?
    iPad Junkie!
    5322
    May 2010
    Newmarket, ON
    104
    Quote Originally Posted by Matth3w View Post
    No, the 3G version has a dedicated GPS just like the iPhone. It uses cell towers to assist, aGPS, but also has a dedicated satellite GPS too.
    I've tried it with no sim installed and no wifi and it works
  1. O2 3G wifi
    By Doncaosdelanada in forum iPad Carriers
    Last Post: 06-28-2010, 01:45 AM
  2. Wifi+3G?
    By skipper in forum iPad General Discussions
    Last Post: 05-25-2010, 10:25 AM
  3. Wifi vs 3G wifi speed/reception
    By CPMS in forum iPad General Discussions
    Last Post: 05-03-2010, 10:25 AM
  4. WiFi VS. WiFi + 3G WiFi Issues
    Last Post: 05-01-2010, 12:26 PM
  5. WiFi VS. WiFi + 3G Release
    Last Post: 03-11-2010, 01:48 AM
can i use google maps without wifi ipad
can i use maps on ipad without wifi
can you use maps on ipad without wifi
does google maps on ipad work without wifi
how to save a map to ipad without wifi
how to use maps on ipad without wifi
ipad google maps without wifi
ipad mapping without wifi
ipad maps without wifi
maps for ipad without wifi
use maps on ipad without wifi?
will my map app work without wifi
Tags for this Thread
