AT times my iPad will freeze. What is the best thing to do when this happens?
This is a discussion on Ipad help. within the iPad General Discussions forums, part of the Apple iPad Discussions category; AT times my iPad will freeze. What is the best thing to do when this happens?...
Perform a reboot.
Press and hold the Power and Home buttons until the white Apple logo appears - it takes a while, but have faith - it will appear. The iPad will reboot - again it takes a while.
No apps or user data are lost - it's nothing more than a reboot, and how many times have you had to do that on your PC.
No need to worry too much to, unless it's a frequent occurrence.
It happens on occasion. Last time I was deleting some email. Thanks and that is what I do, but was making sure it was the thing to do.Originally Posted by Tim SPRACKLEN
If it doesn't freeze but apps misbehave or quit then there's another way....
