Results 1 to 3 of 3
    87785
    Aug 2011
    ipad notes problem
    I have an ipad1, use notes a lot. started facing one problem; i make a note, save it, and when i go back to continue that note, it creates a new note with the same name, the old version still exists. why does it create duplicate notes, it never did this before. any help on this?
    116 times
    15,249
    87785
    Aug 2011
    Hi Tim, did both the fixes recommended, seems okay, but will know if the problem shows up again, after using for a couple of days I guess. Thank you very much for the help !
  1. Notes Problem on iPad
    By chris northants in forum iPad Help
    Last Post: 03-14-2013, 10:59 AM
  2. Ipad 2 -notes synch problem. Pls help.
    By gcampo in forum iPad Help
    Last Post: 07-15-2011, 05:03 PM
  3. Notes App deletes notes
    By JeepFreak in forum iPad Apps
    Last Post: 05-18-2011, 06:59 AM
  4. Replies: 4
    Last Post: 05-04-2011, 10:25 AM
  5. Replies: 2
    Last Post: 09-13-2010, 01:05 PM
duplicate notes ipad
duplicate notes on ipad
how do you save notes on ipad
how to save notes on ipad
ipad duplicate notes
ipad notes app problems
ipad notes duplicating
ipad notes not saving
ipad notes save
problem with ipad notes
saving ipad notes
saving notes on ipad
