Annoying problem with Atomic browser
This is a discussion on Annoying problem with Atomic browser within the iPad General Discussions forums, part of the Apple iPad Discussions category; I've got the Atomic browser app which I find to be excellent and way better than Safari, except for one very annoying problem which I'm ...
Results 1 to 8 of 8
    84587
    Aug 2011
    10
    I've got the Atomic browser app which I find to be excellent and way better than Safari, except for one very annoying problem which I'm unable to solve:
    I use on-line banking regularly which involves a few security login steps. When I use Atomic to try and log in, I get to the last login screen but then it always reverts to the first login step. This happens no matter which browser identity I use. When I use Safari, I can login fully without any problem.
    Can anyone help me solve this mystery?
    iPad Wizard
    49745
    370 times
    6,602
    Does your bank have an app you can use, instead of the browser?
    29345
    50 times
    Penarth, Wales, UK
    1,936
    i use Atomic because i find it the next best thing to Safari, only because safari doesnt support tabs. but it soon will
    have you tried changing the 'identify browser as' setting to safari desktop?
    61094
    6 times
    Jun 2011
    271
    Quote Originally Posted by sjleworthy View Post
    or any of the other options to see if one works.
    84587
    Aug 2011
    10
    Quote Originally Posted by K1W1 View Post
    As I mentioned in my op, I've tried all identities - makes no difference.
    To answer the other question, my bank does have an app, but it's severely limited and not suitable for my purposes.
    I could understand that there may be some insoluble security issue with my bank related to using the iPad for this purpose, but the fact that Safari presents no problem is a real mystery to me.
    iPad Wizard
    49745
    370 times
    6,602
    Quote Originally Posted by cruiser51 View Post
    Don't know why the difference, but you might email the Atomic browser developers and ask. They seem on the ball about adding features. Even if you don't get what you want, you might get an explanation.
    From my experience with Atomic, it has great features, but is more limited when opening various links and is more effective at blocking popups compared with Safari. Maybe there are tradeoffs being made in access vs. security? I find it weird, though, that apparently innocuous links won't open in Atomic. I've pasted ones in forum posts, tested in Atomic and found they wouldn't open, but opened fine in Safari, for instance.
    67132
    Jun 2011
    15
    Pop-up blocking could possibly be the culprit. If there is a pop-up as part of the security chain, then not seeing it (and thus not using it) might cause a revert to the start of the chain again.
    84587
    Aug 2011
    10
    Quote Originally Posted by larla View Post
    This sounded really promising larla, so I temporarily disabled ad blocking in Atomic but it makes no difference. The login sequence still throws me back to the first step!
    I've taken some earlier advice and sent an email to the developers.... will keep you posted!
  1. Problem with Atomic browser openning webpage saves
    By ajikoe in forum iPad General Discussions
    Last Post: 03-19-2011, 02:45 AM
  2. Atomic web browser
    By Diane B in forum iPad General Discussions
    Last Post: 03-16-2011, 12:04 AM
  3. Atomic Web Browser
    By b00bie in forum iPad General Discussions
    Last Post: 03-04-2011, 09:49 AM
  4. Atomic Web browser problem
    By bbmountain in forum iPad General Discussions
    Last Post: 11-27-2010, 12:23 PM
  5. Atomic Web Browser
    By Takenover83 in forum iPad Apps
    Last Post: 04-18-2010, 09:28 PM
atomic browser ipad sound
atomic browser no sound
atomic browser pop up blocker
atomic browser problems
atomic turn off pop up
atomic web broser audio problems
atomic web browser audio
atomic web browser no sound
atomic web no audio
atomic web no sound
disable pop up blocker atomic
turn off pop up blocker atomic web browser
