Why is it that when I do a speed test on my laptop I achieve 38 Mbps, we are on Virgin media, but a speed test on my ipad1 and the wife's ipad2 only achieves 10-15 Mbps? We are using a newer 'N' router. Any ideas?
This is a discussion on Broadband speed tests. within the iPad General Discussions forums, part of the Apple iPad Discussions category; Why is it that when I do a speed test on my laptop I achieve 38 Mbps, we are on Virgin media, but a speed ...
im plugged into virgin media cable too. my desktop says 50 whereas my ipad 2 is 15. this is the ipad hardware limit one suspects.
While the iPad supports N routers, it does not support the whole shebang. Without going into the technical details (which I don't remember anyway) your laptop probably supports the full spec, which includes multiple data channels and other speed enhancing tricks. The iPad can handle the 'n' frequencies and modes, but only handles one, maybe two channels. As I said, I don't remember exactly.
Or as sjleworthy said, it's a hardware limit.
Is that some sort of T1 connection or something as my lowly broadband connection is clocking around 5Mbps if the stars are in alignment.
Sent from my iPad 32/3G using iPF
My speediest apps only test to 20 and 27 m.
It may or may not have any effect, but try setting your router to 802.11a/n or 802.11b/g/n or 802.11b/g compatible and see if that changes your iPad's connection speed.
I can constantly get 25Mbps down and 22.5Mbps up on our Macs and about 18 to 19Mbps down and 16 to 18Mbps up on our iPad using the "Automatic" setting (which is 802.11b/g/n) on our Airport Extreme. Of course it all depends on what part of our house the iPad is in. I conduct the tests (http://www.speedtest.net/mobile.php) with the iPad in the same room as the WiFi router.
As twerppoet points out, the iPad's WiFi system is not equal to those used in computers (in large part to save battery power). However I'd agree that yours should be doing better if you have a decent signal.
How do you check your iPad broadband speed?
I recommend speed of me!
speedof.me is an awesome html5 speed test website which works on iPhone and iPad without installing anything.
hi kabuki,
I checked my internet speed at Scanmyspeed.com .I got accurate results
My speed test results are
Download speed:2.23Mbps
Upload speed:0.749Mbps
Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
iPad 2 32GB Black iOS 5.0.1
iPhone 4 16GB CDMA Black iOS 5.0.1 (jailbroken with redsn0w)
MacBook Air 13.3 in. 128 GB Flash Storage
Super Moderator@ iPadForums.net
