Results 1 to 4 of 4
    77762
    Jul 2011
    Toronto
    34
    Weather too hot for iPad?
    Hi,
    A couple weeks ago, it was really hot out side (35 degree or so), I was out with my iPhone and the a msg popped up on the screen saying the phone's temperature was too hot and it needed to cool down.
    It's just as hot today, I'm thinking about taking my iPad outside to the park. But not sure if it can handle the heat. Has anyone encountered similar issues?
    13582
    4 times
    Aug 2010
    Indiana
    342
    Yes, I have a custom mount I built in my convertible for my iPad and was out with the top down and the iPad shut down because it got too hot.
    There is only one Return, and it's not Of The King, it is Of The Jedi.
    34197
    2 times
    Feb 2011
    USA
    150
    I suppose like any electronic device it would be prone to overheating. Just try to avoid letting it bake in the sun and it should be okay.
    Sent from my iPad2 using iPF
    80444
    Jul 2011
    14
    Wow, that must be hot. Unlike my laptop, I can never feel heat coming from My Ipad 2 itself. I suppose that is part of the reason why it has a 10 hour battery life, because it's pretty efficient.
    Of course, it makes sense that all electronic devices are prone to heat at some point in time unless designed specifically to combat it...
  1. Weather elements for ipad
    By Ilikeapps in forum iPad Hacking
    Last Post: 12-12-2011, 10:26 AM
  2. Replies: 3
    Last Post: 04-04-2011, 12:25 PM
  3. Replies: 0
    Last Post: 04-02-2011, 01:14 PM
  4. WeatherGod the first weather changer for iPad and iPhone!
    By Petra Systems in forum iPad Apps
    Last Post: 02-21-2011, 01:28 PM
  5. Weather.com
    By nateccnn in forum iPad General Discussions
    Last Post: 02-17-2011, 09:08 AM
ipad and hot weather
ipad hot climate
ipad hot weather
ipad in hot weather
ipad not working in hot weather
ipad under hot weather
ipads and hot weather
ipads in hot climates
use ipad in hot weather
using ipad in hot weather
using ipad2 in hot weather
what temperature can ipad handle
