Battery life
This is a discussion on Battery life within the iPad General Discussions forums, part of the Apple iPad Discussions category; Will I be adding to the battery life by using my iPad plugged in?...
Results 1 to 4 of 4
Thread: Battery life
    80098
    Jul 2011
    Battery life
    iPad Junkie!
    46597
    Canada
    166
    Your will battery will go up when you use it while its charging. The ipad charges pretty fast
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    First, welcome to the forum -
    Second, I'm assuming that your question is if you leave your iPad plugged in most of the time (i.e. w/o the battery discharging), will the battery last longer?
    Well, the short answer is NO - the Lithium-ion battery technology is pretty mature at this point; the battery is meant to be discharged periodically (not completely - maybe to 20% remaining charge) and should last for many charging cycles, i.e. you likely will replace your iPad before the battery gives out!
    There will be be many opinions given w/ some likely conflicting - take a look HERE for some more information and checkout the advice on the iPad Guide book.
    80098
    Jul 2011
  1. 4.3 and battery life?
    By Cornicer in forum iPad OS
    Last Post: 08-18-2011, 10:42 AM
  2. Battery life
    By the_john in forum iPad 2 Forum
    Last Post: 03-29-2011, 08:58 PM
  3. Battery life
    By User77 in forum Off-Topic
    Last Post: 03-02-2011, 01:22 AM
  4. 3G Battery Life !?
    By emilyjane918 in forum iPad General Discussions
    Last Post: 05-04-2010, 10:14 AM
  5. 3G Battery Life
    By msskarina in forum iPad General Discussions
    Last Post: 05-02-2010, 08:12 AM
apple ipad battery life
battery
battery life
forums apple ipad battery
ipad 22 battery life
ipad battery life
will ipad battery last longer plugged in
