Battery drain is it Safari?
This is a discussion on Battery drain is it Safari? within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hi My battery seams to drain a lot when not in use and wondered if it is because I have 7 or 8 pages open ...
Results 1 to 4 of 4
    7096
    Jun 2010
    portsmouth
    64
    Hi
    My battery seams to drain a lot when not in use and wondered if it is because I have 7 or 8 pages open in the background in Safari, wondered if they kept updating or if they are like snapshots and only update when I activate the page to view, should I close these pages down each time before putting the iPad to sleep with the smart cover?
    Is the any other things I should look to do, I only use the wireless at the moment as my wife has our shared sim in her iPad,
    ____________________________
    64Gb iPad2 WIFI +3G Black, Black Leather Smart Cover, Black Cool Banana Skin, Pogo Stylus
    119 times
    15,248
    Quote Originally Posted by Archer View Post
    Hi
    You are right - they are just 'snap shots' and no updating is being done, so there's no need to close those pages. When you say that your battery drains a lot when not in use, how much are we talking about here? There's not much background activity when the iPad is in Sleep - it will check for email updates, if you've set that up - and WiFi and GSM will be active, unless you've switched them off, but that's about all. Some Members have commented that, if you have Apple's 'Ping' service activated that seems to drain the battery quite quickly but, other than that, I can't think of any particular reason why you should be seeing this.
    Is this a new problem that you're experiencing, or has it always been like this?
    67852
    Jun 2011
    uk
    5
    the altermator is bad... and also your battery is old. and is not holding the charge...
    but if you have some tools you can remove your alternator and take it to a autozone or places like that, and they can check if your alternator is bad or is your battery that is not holding the charge..
    7096
    Jun 2010
    portsmouth
    64
    iPad is only a couple months old, but only just started using it on a daily basis, I shall monitor over the next couple of weeks.
    Thanks for the feedback
  1. iPad Battery Drain
    By SallySparrow in forum iPad General Discussions
    Last Post: 04-26-2013, 07:00 AM
  2. Battery drain query.
    By ipadsi in forum iPad Hacking
    Last Post: 04-07-2011, 10:07 AM
  3. tweaks that cause battery drain
    By beatlejohn in forum iPad Hacking
    Last Post: 02-18-2011, 10:20 AM
  4. Battery Drain??.
    By David Vice in forum iPad FAQ
    Last Post: 02-06-2011, 03:05 AM
  5. How to drain battery
    By Kim in forum iPad Help
    Last Post: 10-29-2010, 05:23 PM
does safari drain battery
ipad safari battery
ipad safari draining battery
iphone drain battery when i use safari
iphone safari drains battery
safari battery drain
