Audio Volume
This is a discussion on Audio Volume within the iPad General Discussions forums, part of the Apple iPad Discussions category; I use a metronome app and I can't get enough volume from the built in speaker. Can I plug into the headphone jack and connect ...
Results 1 to 3 of 3
Thread: Audio Volume
    46486
    Ottawa,Canada
    Audio Volume
    I use a metronome app and I can't get enough volume from the built in speaker. Can I plug into the headphone jack and connect to an external speaker of some type.
    thank you
    29345
    55 times
    Penarth, Wales, UK
    1,996
    Yes. Using this method you can plug into any speakers that use the standard headphone jack connector. That's how I do mine
    50680
    May 2011
    UK
    127
    Quote Originally Posted by Harreec
    thank you
    You can plug it into the AUX input of your hi-fi or amp. That's how I listen to radio stations. The amp will boost the volume. You probably need a cable with a 3.5mm jack on one end and whatever jacks you have on your amp on the other; readily availabe from most electronic stores.
  1. Volume
    By babs in forum iPad Help
    Last Post: 05-31-2011, 01:02 AM
  2. Volume boost?
    By KenjiBeast in forum iPad Hacking
    Last Post: 04-23-2011, 11:30 PM
  3. iPad headphone audio v dock audio; is there a difference?
    By Pagliacci in forum iPad General Discussions
    Last Post: 04-09-2011, 09:26 AM
  4. Will Skyfire stream audio from flash audio player?
    By wahoowad in forum iPad General Discussions
    Last Post: 04-03-2011, 03:54 PM
  5. app volume
    By meagain in forum iPad General Discussions
    Last Post: 01-14-2011, 02:56 PM
amplifier to boost sound from i padwhen connected to hifi
boost sound ipad 2 external speakers
hook speaker up to metranome
hooking an ipad to a amp for external speakers
how to boost ipad sound
ipad audio volume
ipad headphone boost
speaker boost
