Weird battery life problem
This is a discussion on Weird battery life problem within the iPad General Discussions forums, part of the Apple iPad Discussions category; I would try a restore. I heard it helps the battery life. I have to try it on my ipad wifi. Even though I don't ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    iPad Junkie!
    2107
    Apr 2010
    183
    I would try a restore. I heard it helps the battery life. I have to try it on my ipad wifi. Even though I don't have a problem with battery
    Proud owner of a 32gb iPad
    Owned iPhone 3G
    Owned iPhone 3GS
  3. #12
    2240
    Apr 2010
    Miami moving to GA
    103
    YAY, the problem seems to have stopped. I just reset the iPad then drained the battery. After a night of charging all is well.
    It does bring to light a frustration as a windows user. NO TASK MANAGER....
    My favorite animal is steak.
  4. #13
    iPad Guru
    1284
    7 times
    Mar 2010
    2,623
    Quote Originally Posted by lowlife View Post
    Well, unless you jailbreak the iPad there is no need for a task manager since it will only allow one non-system app to run at a time. If you are jailbroken you can install SBSettings, it includes a task manager that lets you kill any running applications and clear memory if anything is somehow persisting after close.
  5. #14
    2240
    Apr 2010
    Miami moving to GA
    103
    Quote Originally Posted by gentlefury View Post
    Good point. This is a one task at a time device. The reason that I want a task manager is because I felt that something was running in the background as Numlock suggested.
  6. #15
    deoknam
    Guest
    Thanks for the sound advice!
  7. #16
    iPad Enthusiast!
    5171
    May 2010
    54
    Funny i saw the wifi data xfer circle thing on my iPad just going and ping. My battery went down like 29 percent in like ten mins. I rebooted but my battery still isn't last like it normally does
  8. #17
    2614
    Apr 2010
    Nebraska
    208
    I would highly recommend "SYSTEM Manager for iPad"
    Great for checking out what is going on in your iPad.
    The processes page shows you what Apps are running,
    and what processes are running and how much memory they are using.
    Googling the processes, especially high resource using ones, can help to figure out what might be going badly.
    Example: I searched dataaccessd and iPad, and found several posts where people found solutions, like tweaking calendar settings, or found a corrupt email was causing their problems.
    This App has fluctuated a lot between $1.99, and .99 .
    so far the most complete system help I have found.
    This Space Intentionally left Blank !
  1. 3G Battery Life !?
    By emilyjane918 in forum iPad General Discussions
    Last Post: 05-04-2010, 10:14 AM
  2. 3G Battery Life
    By msskarina in forum iPad General Discussions
    Last Post: 05-02-2010, 08:12 AM
  3. Good news about battery life
    By Seadog in forum iPad General Discussions
    Last Post: 04-03-2010, 01:08 AM
  4. Anyone have tips on preserving battery life?
    By Ghuda in forum iPad General Discussions
    Last Post: 04-01-2010, 05:23 PM
dataaccessd ipad
deep cycle ipad
ipad 3 battery life sucks
ipad battery always 100%
ipad battery always says 100
ipad battery life problem
ipad battery life problems
ipad battery reset
