Results 1 to 4 of 4
    59081
    May 2011
    Ipad 2 is slower to recharge and lower battery power than ipad 1
    Dear all,
    I just got my new ipad 2 64GB 3G i found that with all the same setup, ipad 2 is slower to recharge approx5 hours and the battery doesnt last as long as ipad1.
    Help pls? May be i set itwrongky?
    58998
    May 2011
    5
    I am new user to iPad I am using iPad 2 wifi I choose the same because the 3G draws more power as per ur service provider range ie is the sim card ur using. I have a baundlux portable router and I am happy with the performance since even I can connect my iPad and iPhone at a time with a single connection.
    Cheers
    624 times
    Dayton, WA
    13,312
    Is the iPad 1 running the most current software revision?
    Some people have reported battery life improvements if they go into the Restriction under General settings and turn off Ping. This is a fairly new feature added in the 4.3.x iOS, if memory serves.
    15304
    Sep 2010
    Vancity
    178
    I disagree, Ive tested both ipads out and the iPad 2 actually has a better life than the iPad 1. I think it just depends on the charing cycles that the iPad 1 have been put thought proior to testing it.
    iPad 2 64GB 3G Black,
    iPad 1 64GB 3G,
    iPhone 4 32GB Black,
    iPod 3rd Gen. 32 GB White.
  1. Sudden loss of battery staying power:help
    By Snowlady in forum iPad Help
    Last Post: 11-04-2011, 07:21 PM
  2. How To Restore To New iPad With Lower IOS Ver?
    By Ultrafire88 in forum iPad Help
    Last Post: 04-16-2011, 10:32 PM
  3. IPAD Wifi slower than dialup
    By 1298767 in forum iPad Help
    Last Post: 01-27-2011, 03:16 AM
  4. When should i recharge
    By Khanandranii in forum iPad General Discussions
    Last Post: 01-04-2011, 08:07 AM
  5. Battery Power and Router recommendation
    By Kenworth in forum iPad Help
    Last Post: 08-07-2010, 02:29 PM
how do you power recharge an ipad2?
how to recharge ipad 2
i pad 2 slow recharging
ipad 2 recharge time
ipad 2 slow battery recharge
ipad 2 to long to recharge
ipad battery slow to recharge
ipad slow to recharge
ipad2 recharge time
recharging ipad
when to recharge ipad
when to recharge ipad 2
