Volume control
This is a discussion on Volume control within the iPad General Discussions forums, part of the Apple iPad Discussions category; I have a bit of a strange Problem. I bought the iPad to use on stage to play backing tracks for a band I'm in. ...
Results 1 to 2 of 2
Thread: Volume control
    57223
    May 2011
    Volume control
    I have a bit of a strange Problem. I bought the iPad to use on stage to play backing tracks for a band I'm in. on some songs I like to turn up or down certain parts of the song depending on the location. the problem is the iPad volume control is either to loud or to low there is no in between. I noticed that it takes 16 clicks of volume to get from lowest to loudest. My solution would be if I could have 32 clicks from lowest to loudest. Does any one know if there is a hack for this or maybe a 3rd party app to acomplice this. Thanks
    iPad Guru
    30446
    11 times
    3,197
    There is no hack, but you could always use the volume slider, as that allows for finer volume adjustment. But if that doesn't help, there isn't much that can be done about this.
  1. Problem with volume (down) control
    By jmarkhenrik in forum iPad General Discussions
    Last Post: 03-17-2013, 07:14 PM
  2. Volume control on iPad
    By TexasBlondie55 in forum New Member Introductions - Site Assistance
    Last Post: 02-18-2011, 06:33 PM
  3. Sound volume control
    By TFarmer in forum iPad General Discussions
    Last Post: 10-07-2010, 05:10 PM
  4. No volume control while ipad is docked
    By Matenrou in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-28-2010, 02:23 PM
  5. volume control for external microphone
    By old shep in forum iPad Help
    Last Post: 09-24-2010, 04:44 AM
how do i turn down the volume on my ipad
how do i turn the volume down on my ipad
how to control volume on ipad3
how to fix the volume on my ipad3
ipad 3 volume control
ipad sound control
ipad volume control
ipad volume control problem
is there a volumen control on the i pad outside?
volume control ipad 3
volume control on ipad3
where is volume controls located on ipad3
