Draining battery to 1%?
This is a discussion on Draining battery to 1%? within the iPad General Discussions forums, part of the Apple iPad Discussions category; Originally Posted by King.Khoja Is it a bad thing if i let the ipad die out past 1% than charge it? Doesn't really matter. It ...
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 38
  1. #21
    Banned
    12904
    35 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Quote Originally Posted by King.Khoja
    Doesn't really matter. It won't help the battery or really hurt it.
  3. #22
    15304
    Sep 2010
    Vancity
    178
    Ok good, since i got the ipad ive been letting it fully die out before i charge it. Dont wanna drain the battery charging it when it doesnt need a charge.
    iPad 2 64GB 3G Black,
    iPad 1 64GB 3G,
    iPhone 4 32GB Black,
    iPod 3rd Gen. 32 GB White.
  4. #23
    12657
    4 times
    Aug 2010
    Area DM51
    669
    Quote Originally Posted by grayshark95 View Post
    Lithium ion polymer will last longer if you don't drain and recharge.
    Correct! Li-Ion (LiPo, LiCo, LiMn, LiFePO4 and other Li chemistries) will have a longer life if not allowed to discharge completely. Modern devices incorporate sophisticated protection circuitry to avoid serious damage from over-discharge, but bumping down against that limit too often will not do the battery any good.
    The important thing is not to leave the battery in a fully discharged state. Recharge it as soon as possible after discharge. If you have to store the device unused for any protracted length of time (1 month or more) do so with the meter reading about 80%.
    The battery should last around 1,000 full charge cycles - that is, complete discharge and recharge every day for 3 years. Few people will achieve such a heavy use. A part cycle does not count as a full one, so don't be afraid to top it up daily, even from 70-80%. LiPo batteries have no memory effect, and prefer being kept topped up.
    None of us, even heavy users among the very first to get iPads, will be anywhere near exhausting the batteries yet. In 3-4 years' time, if we have not upgraded by then, the symptoms of exhaustion will be a failure to hold charge; the battery will charge up to 100% but then drop back quite quickly (within 15-20 minutes) to a noticeably lower figure even when it has not been used. When it can no longer hold 80% charge, it will be time to retire it.
    By then, users may notice the iPad becoming warm (or even quite hot) during recharging. Heat is not a good sign; the problem will increase as the battery's life approaches its end, to the point where it becomes dangerous. By then the device is likely to exhibit other signs of malfunction. Further persistence at that stage would be a bad idea as a battery that overheats can eventually suffer thermal runaway, at which point it will go off like a firework and vent with flame, producing extremely toxic gases in the process.
    However... the greatest likelihood is that the battery will simply just gradually fade out, with none of the drastic worst-case scenarios occurring; and it isn't going to happen to any of us for quite a long time yet.
  5. #24
    Banned
    12904
    35 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Thank you for that long explanation!
    It furthered my understanding of lithium polymer batteries.
  6. #25
    iPad Enthusiast!
    10964
    Jul 2010
    Bohinj, Slovenia
    51
    Some good answers, thanks. I have one more.
    Is it OK to charge an iPad over night on a regular basis?
    I once charged a set of AAs a few hours past their 'full' state and it melted the entire unit.
  7. #26
    Banned
    12904
    35 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Quote Originally Posted by Studor13
    iPad will stop at full and "trickle charge" meaning it only sends enough voltage to the battery to keep it full. That will not hurt the battery.
  8. #27
    110348
    Oct 2011
    FL
    7
    As my name implies, I'm new to this. What you say makes sense. Why though does the User Guide say:
    "Maximizing battery life
    iPad uses a lithium-ion battery. For information about maximizing the battery life of iPad, go to www.apple.com/batteries/ipad.html."
    And from that website:
    "Use Your iPad Regularly
    For proper reporting of the battery's state of charge, be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down)."
    Am I reading an outdated Guide? Please clarify.
  9. #28
    153195
    3 times
    Jan 2012
    east islip
    203
    if the book says to run it down once a month then we should follow it.
  10. #29
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Quote Originally Posted by ipad2tyro
    The guide is correct, you only need a full charge cycle once a month to calibrate the battery meter, no other reason.
    110348
    Oct 2011
    FL
    7
    Quote Originally Posted by Gabriel1 View Post
    Thanks! Just love my new iPad and wouldn't want to do anything to shorten its life.
  1. iPad 2 battery draining quicker. help.
    By z4_ryan in forum iPad 2 Forum
    Last Post: 08-17-2011, 07:20 AM
  2. Tips on draining ipad battery?
    By Mv-ixius in forum iPad General Discussions
    Last Post: 01-02-2011, 10:33 PM
  3. Battery Draining
    By dhender in forum iPad Help
    Last Post: 12-25-2010, 01:37 AM
  4. Battery draining quicker than expected
    By Yoshiki UK in forum iPad Help
    Last Post: 07-23-2010, 10:44 AM
  5. What have I downloaded that is draining the battery?
    By barriejohn69 in forum iPad Hacking
    Last Post: 07-20-2010, 05:47 PM
bad to let ipad die?
how to calibrate ipad battery
ipad bad battery symptoms
ipad battery drains to 2%
ipad wont charge past 1%
is it bad to let ipad battery die
is it bad to let ipad die
is it bad to let your ipad dies
