Battery drainage - WiFi vs 3G
This is a discussion on Battery drainage - WiFi vs 3G within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hello! I have the iPad 2 3G and I'm wondering about the drainage of the battery. Hope you can help me out. 1. If I ...
Results 1 to 2 of 2
    iPad Enthusiast!
    47284
    40
    Hello!
    1. If I have both 3G and WiFi activated at the same time I'm guessing that iPad is using the WiFi connection, right?
    2. Does this also mean that it uses more battery (if 3G and WiFi is connected/activated at the same time).
    3. What is using the least battery: 3G or WiFi?
    Thanks in advance!
    49194
    43
    when you turn both on, ipad will prefer wifi, then if no connection, it will be on 3g. if continuous usage, i find 3g drains faster than wifi, esp. if the signals aint that great.
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. Battery drainage?
    By derm318 in forum iPad General Discussions
    Last Post: 04-14-2011, 12:26 PM
  3. how turn wifi OFF/ON without the need to reenter wifi password
    By lse123 in forum iPad General Discussions
    Last Post: 07-08-2010, 11:06 PM
  4. Sold my 16gb wifi and wait for 32gb wifi is killing me
    By Ian B in forum iPad General Discussions
    Last Post: 06-29-2010, 06:19 PM
  5. Setting up Verizon Blackberry Tour Wifi Hotspot for Ipad Wifi
    By xlr8nflorida in forum iPad General Discussions
    Last Post: 06-14-2010, 11:09 PM
does 3g drain battery faster than wifi
does 3g drain battery faster than wifi?
does 3g or wifi drain battery faster
does using wifi drain battery faster than 3g
does wi-fi drain battery faster than 3g
does wifi drain battery faster than 3g
does wifi drain battery faster than 3g?
ipad 2 wifi and 3g connection same time
what conection is faster 3g or wifi
what drains the battery more wifi or the network
which connection is faster wifi or 3g
will wi-fi kill battery quicker than 3g
