Forgive me if this has al ready been brought up. If I have both wifi And 3G on which will the Ipad chose as it's main data stream.
This is discussed here https://discussions.apple.com/messag...ageID=12856807
Basically wireless takes precedence except when the ipad is asleep when wifi is turned off to save power then push email and other data will use 3G.
I'm doubting the second part is true for iPads. I certainly get push notification on my Wifi only when it is sleeping. When I had my 3G iPad 1, it got push notifications when sleeping, even if the 3G was turned off.
I'm not certain about how iPhones work, but since they have to have the 3G on all the time and have a smaller battery, it would make sense to shut down the WiFi under certain conditions. It does not make as much sense to do this with the iPad. You are better off shutting down the 3G, which tends to uses more battery than the WiFi radio, especially if your signal is weak.
Here is the last entry from my 3G usage from vodafone
Data/GPRS26 Apr
14:28
Data/GPRS
Peak
0.016
$0.00
There are lots of small entries like this and my ipad has been at home and connected to my wifi for the last five days (very long weeked in Australia). The only large entry was from the day I installed my MicoSIM and tested 3G with WiFI turned off. So it does seem to be true for me (Ipad 2 3G 32G).
The data seems to support you, but being a stubborn sort of person I'll probably muck about looking for collaborating evidence before I admit the error of my ways.![]()
Thanks...the Telecom NZ usage meter has changed ( for the better) and shows every item of data usage. I couldn't understand why it was showing data usage when I knew I was in a wifi zone. So...recommendations for saving 3 G? Turn it off while in wifi? I think that is annoying. Or turn off push notifications? What are e implications of that?
