Dsl wireless router settings
This is a discussion on Dsl wireless router settings within the iPad General Discussions forums, part of the Apple iPad Discussions category; I have dsl running ppoe and router set for 2 iPads. I set router for "stay connected". But when iPad cover is closed for a ...
Results 1 to 2 of 2
    48915
    Usa
    I have dsl running ppoe and router set for 2 iPads. I set router for "stay connected". But when iPad cover is closed for a minute, I'm forced to choose a network again when I open the iPad and go to Internet. Is there a setting that would allow continuous network connection even after reopening the iPad?
    577 times
    Dayton, WA
    13,177
    I'm pretty sure your router's 'stay connected' setting refers to it's connection to the sever, not your iPad's connection to it. They should be unrelated.
    Unfortunately some routers and the ipad just do not get along. Sometimes you can adjust it to work properly, but it's so specific to each router that usually, after a lot of messing around, most people choose to just get a newer router. You can always contact your provider (if they supplied the router) or the manufacturer to see if they have a fix.
    But there are a few things worth trying first. This more or less combines them all into one.
    Shut off your router.
    On the iPad, go into Settings >> General >> Reset, and choose Reset Network Settings.
    Restart your iPad. Hold down the power button until the red power off slider appears and slide it off. After the iPad shuts down, hold down the power button again until you see the Apple logo.
    Turn on your router and wait for it to finish rebooting.
    If the iPad does not ask if you want to join the network, after the router reboots, go to Settings >> Wi-Fi and manually join your network.
    Test to see if it works properly now, and continue to monitor over the next few weeks to make sure the problem does not reappear, at lest not too often.
  1. Mifi wireless router
    By Jasper@xntric in forum iPad General Discussions
    Last Post: 04-10-2011, 03:46 PM
  2. Wireless router advice needed
    By Lisab in forum iPad 2 Forum
    Last Post: 04-10-2011, 11:23 AM
  3. Time Capsule/Wireless Router
    By Kingsmuse in forum Off-Topic
    Last Post: 12-14-2010, 05:21 PM
  4. Dual Band Wireless Router ??
    By Kenworth in forum iPad Help
    Last Post: 10-06-2010, 12:31 PM
  5. Wireless router
    By whoachubby in forum iPad General Discussions
    Last Post: 07-07-2010, 01:22 PM
best router settings for ipad 2
best wireless settings for ipad 2
connecting ipad to dsl router
dsl on ipads
how to set up ipad 2 from dsl
how to set up wireless router for ipad
ipad connect dsl wireless
ipad stay on wireless network
router best setting ipad
setting up dsl with ipad verizon
trouble connecting ipad to dsl network
wireless router settings on ipad2
