Battery problem
This is a discussion on Battery problem within the iPad General Discussions forums, part of the Apple iPad Discussions category; My battery has been draining about 5% an hour while asleep with no apps running. I read online that restarting the ipad should fix it, ...
Results 1 to 5 of 5
Thread: Battery problem
    38802
    31
    Battery problem
    My battery has been draining about 5% an hour while asleep with no apps running. I read online that restarting the ipad should fix it, and I did that, but the problem was still there.I decided to drain the battery completely and then recharge it to 100%. I did that, and now the battery is stuck at 100%. Ive been using it for 3 hours and its still at 100%. What can I do to fix this?
    46871
    PA
    If you have apps running in the background they will put a slow drain on your battery. Close any apps that you are not using. Hope this helps.
    iPad Enthusiast!
    38154
    UK
    54
    I dunno about the being stuck at 100% problem. But the battery drainage while asleep problem is usually because of wifi or 3G being on, and fetching new data.
    Sent from my iPad 2 using iPF
    45397
    16
    If you are noticing your battery power dropping faster than you think it should you will need to become familiar with the options in the "settings" icon.
    You have the ability to turn everything on and off from the settings app. It will not manage itself and it makes a difference.
    3G is expensive. GPS is expensive. WiFi is less expensive.
    Each of these needs it's own type of radio to give you that service.
    Each type draws it's own power.
    There is no way yet to manage these radios besides the settings app.
    It is not as effortless as I would like it to be. An icon that toggles wifi on and off from the desktop would be nice. Not possible yet. Not till you can script iOS.
    Power in a device like this is probably going to need your direct management for a long time to come. Heavy users usually end up with everything on and many places to keep plugged in. That is the easiest answer.
    Banned
    40587
    Sochi, Russia
    130
    Backgrounder and 3G unrestrictor can cause drainage, depends on what u have there running.
  1. Battery problem with ipad2?
    By fredhatfield in forum iPad 2 Forum
    Last Post: 01-17-2012, 06:55 AM
  2. Battery problem ?
    By jimfastcar in forum iPad Help
    Last Post: 03-13-2011, 11:52 AM
  3. Battery problem
    By Tootall in forum iPad General Discussions
    Last Post: 01-25-2011, 04:04 PM
  4. iPad NOT CHARGING Battery Problem Fix
    Last Post: 01-22-2011, 01:56 PM
  5. Weird battery life problem
    By lowlife in forum iPad General Discussions
    Last Post: 06-09-2010, 04:20 AM
apple ipad2 recalls battery
ipad2 battery recall
is there a recall on ipad 2 battery
