Battery drainage?
This is a discussion on Battery drainage? within the iPad General Discussions forums, part of the Apple iPad Discussions category; Should the battery of the iPad1 drain while it is off? It appears to be happening to me....
Results 1 to 3 of 3
    45948
    Tucson
    Battery drainage?
    116 times
    15,249
    When you say 'off' do you mean this - or is the iPad in Sleep mode.
    When you briefly touch the Power key you put the iPad into Sleep mode and, then, several things are still running - such as WiFi and 3G, if they're turned on in 'Settings' - and your iPad may occasionally check for email - again if you've asked for this in Settings.
    If you've really switched the iPad off - by holding down the Power key for a couple of seconds and then sliding the control to authorise the iPad to switch off, then the battery drain should be very small.
    You can read Apple's official line on the iPad battery here
    Apple - Batteries - iPad
    42250
    Riverside, CA
    100
    I guess I am lucky, at night I put it in sleep mode and in the morning it still reads the same as the night before.
  1. The battery!
    By normanj in forum iPad General Discussions
    Last Post: 03-07-2011, 09:40 AM
  2. Battery
    By Larrybe in forum iPad Help
    Last Post: 01-02-2011, 11:07 AM
  3. Battery?
    By HUNTER1 in forum iPad General Discussions
    Last Post: 11-30-2010, 09:31 AM
  4. Battery in IOS 4.2.1
    By skatealex2 in forum iPad OS
    Last Post: 11-29-2010, 07:07 PM
  5. how does the battery like this???
    By Spielor in forum iPad General Discussions
    Last Post: 10-29-2010, 12:52 AM
