Iphone sync cable not same as ipad cable
This is a discussion on Iphone sync cable not same as ipad cable within the iPad General Discussions forums, part of the Apple iPad Discussions category; Question for the group concerning cables... If the cables are all the same, as some suggest, why are the non-USB sides (the one that connects ...
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 37 of 37
  1. #31
    9323
    Jul 2010
    Southeast Wisconsin
    674
    Question for the group concerning cables... If the cables are all the same, as some suggest, why are the non-USB sides (the one that connects to the iPad) of different sizes? I've purchased a few different cables and they seem to be different sizes. Any thoughts?
    Sent from my IPad
  3. #32
    80624
    Jul 2011
    Mine have the same size.
  4. #33
    81912
    Jul 2011
    6
    Quote Originally Posted by cannedbrain View Post
    Mine also, definitelly nothing to care
  5. #34
    109811
    Oct 2011
    DFW Texas
    I have purchased apple usb cables for my iPhone. They sync the iPad2 but do not charge it.
  6. #35
    Banned
    109936
    Oct 2011
    6
    my old cable worked fine
  7. #36
    80624
    Jul 2011
    Quote Originally Posted by railrodder View Post
    If you bought it from an Apple Store, bring it to them to get a replace. My iPhone cable went bad after 2 years and couldn't sync or charge either iPhone or iPad (1). The replacement I bought works well for both.
  8. #37
    61094
    6 times
    Jun 2011
    271
    Are you saying they won't charge when connected to a USB port or they won't charge when connected to the iPad charger?
    We have 4 iPhones (back to a 3G), two iPads, at least 4 non genuine cables and a couple of iPod USB cables and they all interchange fine and every cable seems to work charging the iPad PROVIDED it's used with the correct charger.
  1. MP4 movie won't sync to Ipad? Help
    By ericejs15 in forum iPad Help
    Last Post: 07-09-2012, 10:53 PM
  2. Apple Component AV Cable and The Netflix app
    By TheBaron in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-24-2011, 08:31 AM
  3. 1st time sync of ipad 3g?
    By www777 in forum iPad General Discussions
    Last Post: 04-30-2010, 08:40 AM
  4. Sync ipad with pc
    By 300cman in forum iPad General Discussions
    Last Post: 04-29-2010, 11:10 PM
  5. Replies: 4
    Last Post: 02-08-2010, 02:19 AM
are all iphone cables the same
cord to sync iphone and i pad
difference between ipad and iphone cable
difference between ipad cable and iphone cable
how to tell the difference between the iphone 5 cord and an ipad 4 cord
ipad cables difference
ipad iphone cord
ipad sync cable same as iphone
is ipad cable same as iphone
is iphone 5 and new ipad data sync cable the same
is the a difference between ipad cable and iphone cables?
is there a difference between an iphone power cord amd a ipad power cord?
