Iphone sync cable not same as ipad cable
This is a discussion on Iphone sync cable not same as ipad cable within the iPad General Discussions forums, part of the Apple iPad Discussions category; All the cables are the same, but the ac adapter is different, an iPod ac adapteer will take forever to charge the iPad, so make ...
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
  1. #11
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    All the cables are the same, but the ac adapter is different, an iPod ac adapteer will take forever to charge the iPad, so make sure you use the charger that came with it.
  3. #12
    sim
    sim is offline
    3247
    Apr 2010
    Rochester, MN
    8
    Quote Originally Posted by Bremen View Post
    I have used my iPhone cable to sync from day one. I have not even taken the one that came with the iPad out of the box...... Have no idea what you are talking about.....
    Ditto. I haven't taken the one that came with my iPad out of the cute plastic wrapper. Been using one of my iPhone ones and my syncs fly....but I only have about 85 apps and 300 or so photos...no music. In the process of downloading a movie from iTunes and will probably load my 9 gigs of music on at some point this weekend which should slow things down.
    Steve
  4. #13
    2764
    Apr 2010
    Michigan
    11
    I have two iphones and two iPads in my house and we constantly use different cables for charging and synching we have not had any problems.
  5. #14
    3025
    Apr 2010
    Pawleys Island, SC
    9
    user error
    Gary J
  6. #15
    iPad Enthusiast!
    3103
    Apr 2010
    47
    Add me to the group that has no problem interchanging iPad to iPhone cables. I use them both depending on where I am.
  7. #16
    iPad Junkie!
    1833
    Apr 2010
    232
    Anyone try after market cables? I see that Monoprice has them for $1.58
    $1.58 each - USB Sync Cable for Apple iPhone/ iPad/ iPod Touch, Classic, Mini, Nano - 6ft | iPod Cables
    Anyone try them yet?
  8. #17
    2614
    Apr 2010
    Nebraska
    208
    Quote Originally Posted by iceman View Post
    Well, wanting it right away, I bought one of the 6 foot cords locally for almost $10.
    I am NOT pleased with it.
    syncing goes fine.
    It shows the charging icon.
    But it is either NOT charging, or charging so slowly I cannot tell that it is.
    Yes, whether it is plugged into USB. OR the charging block.
    Anyone else who has gotten one have input on their experience?
    This Space Intentionally left Blank !
  9. #18
    3742
    May 2010
    FLA
    24
    I too have about 10 Apple cables. iPod touch ones, iPhone ones, and iPad ones.
    All work interchangeably without problems.
    Rampage II Extreme -- Core I7 975 -- 12GB Dominator 1866Mhz--2x X25 RAID0 -- 1.5TB seagate -- 3X GTX 285 -- DVD-RW--BD/DVD -- dual loop liquid cooling w/Danger Den GPU and CPU waterblocks -- 2x Gateway 30" 2560X1600 screens.
    Iphone 3GS -- Ipod touch 2G -- Ipad 3G 32GB -- ALL JB -- Ipad Keyboard -- Ipad Camera kit -- Apple case
  10. #19
    iPad Enthusiast!
    1884
    Apr 2010
    54
    As with others, I'm using multiple cables (all genuine Apple) with no issues. I like the older cables with the lock/release thing, don't like the newer one that's smaller and you just yank out. Not sure how those aftermarket cables would work, especially one that's 6 feet long. What I've noticed is that some of the newer Apple products can be picky about the charging method you use. I've tested one of those cheap eBay wall chargers and my iPhone and iPad won't charge with it (yes I've left it plugged in for a while to verify that it isn't charging really slow). It'll charge my Kensington external iPhone battery fine, but not the iPhone or iPad. Luckily between all the iPhones and ipods I've bought the last few years I have chargers in multiple locations in the house as well as at the office.
  11. #20
    3742
    May 2010
    FLA
    24
    Im sure all of you know this but I thought I would post it anyways.
    The Ipad uses a 10W power to charge. The Iphone and most regular USB connections are 5W.
    When you plug the Ipad up to your computer (unless its a high power USB port) the Ipad will say "Not Charging". It is charging though, but it is charging VERY slowly.
    I accidentally left my ipad hooked up to my computer one night and it went from 84% to 100%.
  1. MP4 movie won't sync to Ipad? Help
    By ericejs15 in forum iPad Help
    Last Post: 07-09-2012, 10:53 PM
  2. Apple Component AV Cable and The Netflix app
    By TheBaron in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-24-2011, 08:31 AM
  3. 1st time sync of ipad 3g?
    By www777 in forum iPad General Discussions
    Last Post: 04-30-2010, 08:40 AM
  4. Sync ipad with pc
    By 300cman in forum iPad General Discussions
    Last Post: 04-29-2010, 11:10 PM
  5. Replies: 4
    Last Post: 02-08-2010, 02:19 AM
are all iphone cables the same
cord to sync iphone and i pad
difference between ipad and iphone cable
difference between ipad cable and iphone cable
how to tell the difference between the iphone 5 cord and an ipad 4 cord
ipad cables difference
ipad iphone cord
ipad sync cable same as iphone
is ipad cable same as iphone
is iphone 5 and new ipad data sync cable the same
is the a difference between ipad cable and iphone cables?
is there a difference between an iphone power cord amd a ipad power cord?
