Can anyone who has experienced WiFi issues with the WiFi only units test on the same router / firewall with a WiFi + 3G to see if the problem still exists?
This is a discussion on WiFi VS. WiFi + 3G WiFi Issues within the iPad General Discussions forums, part of the Apple iPad Discussions category; Can anyone who has experienced WiFi issues with the WiFi only units test on the same router / firewall with a WiFi + 3G to ...
This may not help much, but I connected today at a public hotspot in town and had no issues for the half hour that I was there. 3G is noticeably slower. My 3G connection now is running about 590 kbps.
I want same info as it is possible apple may have made changesOriginally Posted by Sonny Burnett
Sent from my iPhone using Tapatalk
Cheers
Col
col.bris, Brisbane Australia
iPad User Guide
Forum Rules. Please Read.
Hacking Section Rules
I now have both a 3G and wifi model in my home. I also have a dual band router, the signal strength on the wifi only model is noticeably worse than the 3G has been so far today. I haven't had any problems with the wifi only model dropping connections, but the signal strength is worse while sitting in the same spot connected to the same network as the 3G model.
I have not had any performance difference over my laptop, but the iPad usually shows fewer bars. They have already dismounted the 3G and found five antennae in it.
I think only those with both the WiFi and 3G should post replies here, just to get a more technical response. We already know what the WiFi only version behave like on certain routers or hotspots, but comparing them to other devices wont work here, its better comparison between wifi and 3g iPad units. Get it, same unit only one is wifi the other both wifi and 3g but not running 3g, we are comparing the antennas for wifi, nothing really with 3g.
Although the 3G comparison between an iPhone 3GS and iPad 3G would be good for another thread.
That doesn't surprise me. The Wifi has complete aluminium enclosure and has due to that a better shielding. The 3G has for exactly that reason the little black plastic cover. That is the area, where the 3G antenna sits and it is also of benefit for the wifi reception.
But the main problem area on wifi is not the reception. It is a bad DHCP handling issue. That should be resolved with the next firmware upgrade.
Most likely written on my iPad
OK, I am at my cigar store hangout on wifi right now, and have watched vid from ABCand used mail as well as posting this. I've seen absolutely no problem connecting or maintaining connection. I'm just amazed that the wifi speed is more than triple 3G.
