Best battery maintenance?
This is a discussion on Best battery maintenance? within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hi All, I'm curious....is it best to let the iPad run "dry" and then recharge it or just the opposite [charge it as soon as ...
Results 1 to 6 of 6
    42773
    California
    32
    Hi All,
    just the opposite [charge it as soon as possible]. I've heard conflciting opinions about this.
    Best regards,
    Everett
    41793
    11
    I don't remember where I actually saw it but it was an official website such as motorola that said the best thing is to let run down to about 8-10% then fully charge it. Sorry I can't show you proof as I don't remember but I did see that somewhere. Lol
    42773
    California
    32
    Quote Originally Posted by Droidmakespwn View Post
    Thanks for that! I've heard similar things. My new iPad seems to be draining quickly and I think I'll let it drop down below 10% and then
    recharge it fully. I hope that will improve what appears to be poor battery life in my iPad.
    36856
    53
    Apple recommends a full discharge about once a month. From what I read, what's more important is making sure that you don't expose the iPad to temperature extremes.
    According to Apple, the battery should have something like 80% efficiency after 1,000 full charge cycles. Even if you go through a full charge cycle every day (10 hrs of use), that's three years.
    Edited to add that the rate of discharge will depend on what you are doing. I find that downloading videos is a battery drainer - I noticed that I would lose a percent every 4 min. when downloading, as compared to about a percent loss every 6 or 7 min when surfing, and about a percent loss every 8 min when watching videos.
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    http://batteryuniversity.com/learn/a..._ion_batteries
    Support Our Troops!!
    This post was Tapatalk approved. Sent from my Incpad
    iPad Guru
    30446
    11 times
    3,197
    How to preserve battery-life in a nutshell (info extracted from Apple and the above linked source):
    -Charge regularly. It is better to charge twice 50%, then once 100%
    -Charge only to ~95%. The last 5% don't extent the battery life much, but cost performance in the long run.
    -Charge only, when the iPad is not heavily used, I.e. not while gaming. This helps for more accurate battery level reading&charging
  1. Building maintenance apps
    By Jeremy j Hargus in forum iPad Apps
    Last Post: 10-26-2011, 05:16 AM
  2. Couple of newbie maintenance questions...
    By MachThree in forum iPad General Discussions
    Last Post: 12-20-2010, 03:20 PM
  3. Maintenance Apps?
    By hookbill in forum iPad Apps
    Last Post: 10-22-2010, 06:39 PM
  4. Need an App for rental maintenance
    By w7koa in forum iPad Apps
    Last Post: 09-20-2010, 04:34 PM
  5. Battery Maintenance
    By TFarmer in forum iPad General Discussions
    Last Post: 09-17-2010, 10:48 PM
apple ipad battery maintenance
battery maintenance ipad
best battery app for ipad
best battery maintenance app for ipad
best ipad battery app
ipad 3 battery maintenance apps
ipad battery maintenance apps
ipad maintenance
ipad maintenance app
maintenance app ipad
proper ipad battery maintenance
