iPad 2 charging and synch problem
This is a discussion on iPad 2 charging and synch problem within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hey, I had the same problem about charging and syncing. To me it seems like that the usb cable is the problem. I have changed ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    84227
    Aug 2011
    Denmark, Ebeltoft
    Perhaps silly
    Hey,
    I had the same problem about charging and syncing. To me it seems like that the usb cable is the problem. I have changed the cable to one of my old iPhone cables, and now syncing and charging from my MacBook Pro is not a problem.
    And yes, by using the "new" cable, the iPad 2 is "slow" charging.
    Perhaps it will work for you
    Regards
    Peter
  3. #12
    106556
    Oct 2011
    Atlanta, GA
    I had the same problem with my iPad 2 and MacBook Pro (5,3). When I did an iTunes reinstall it fixed the problem. It's syncing and charging from the USB port. I'm still not sure how it started.
  1. Charging Problem
    By sandman1318 in forum iPad Help
    Last Post: 09-20-2011, 03:43 PM
  2. iPad- Redsn0w Jailbreak charging problem
    By Takeover in forum iPad Hacking
    Last Post: 05-13-2011, 02:13 PM
  3. Charging problem.....?!?!?!
    By Wisegoose in forum iPad Help
    Last Post: 03-20-2011, 02:27 AM
  4. iPad- Redsn0w Jailbreak charging problem
    By Andy512 in forum iPad Hacking
    Last Post: 03-05-2011, 03:19 PM
  5. iPad NOT CHARGING Battery Problem Fix
    Last Post: 01-22-2011, 01:56 PM
ipad 2 cannot charge or sync
ipad 2 charging issues
ipad 2 charging problems
ipad 2 charging solution
ipad 2 not charging or syncing
ipad 2 will not charge or sync
ipad 2 wont charge or sync
ipad 2 wont sync or charge
ipad not charging sync
ipad2 not able to sync in laptop
my ipad 2 wont charge or sync
problems charging ipad2
