Is sound quality better from 3.5 mm jack or 30 pin
This is a discussion on Is sound quality better from 3.5 mm jack or 30 pin within the iPad General Discussions forums, part of the Apple iPad Discussions category; I want to listen to tunes on my iPad and pandora in my car from my iPad. I can get analogue out from either the ...
Results 1 to 4 of 4
    32200
    Feb 2011
    9
    I want to listen to tunes on my iPad and pandora in my car from my iPad. I can get analogue out from either the headphone jack or the 30 pin connector which then will connect to 2 RCAs and then my cars system.
    So far I've tried the 30 pin connector and it makes me think that getting digital out with an extra DAC probably cant sound much better, but am curious if anyone has compared the two. Also, how does the 30 pin connection compare with the headphone jack?
    Scott
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    Good question! I used to use the AUX in on my car radio and it sounded OK. Now I have a JVC HD "sound system" in one of my cars and the USB docking cable plugs straight into the head unit and honestly, I don't know that I can hear the difference.
    Other than the possible difference (improvement?) in sound quality, one thing this does allow me to do is use the tagging feature of the radio. Another option (that I don't use) is that it also allows me to control the iPad from the radio. It is a pretty cool feature, but it is still much easier for me, ummmmm... I mean it is easier for my passenger to make the selections directly from the iPad. Why have a big screen if you're not going to use it?
    37425
    7
    What is a good dac to get?
    32200
    Feb 2011
    9
    Dac?
    I wish I knew. If you look on ebay, there are many DACs for about $ 50 and some kits - if you can do some soddering that claim to get you to a very high end product for about $100. Then you have the problem of wireing in some sort of voltage converter to power it. I was convinced that was the way to go until i picked up a 30 pin to 2 rca cable and pluged it into my cars JL CL441DSP Cleansweep. The sound was really good and clean. So, while Im still researching the digital out route, it might be a lot of trouble and expense for no real improvement.
  1. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  2. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  3. Music Via Bluetooth - Sound Quality?
    By RAC in forum iPad General Discussions
    Last Post: 01-25-2011, 08:34 PM
  4. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
  5. HEADPHONE JACK IN IPAD MAY ACCEPT HEADSET? This headset must has only one jack?
    By lse123 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-23-2010, 06:13 AM
3.5 mm vs 30 pin
3.5mm vs 30 pin
30 pin to 3.5mm
30 pin to 3.5mm jack
30 pin vs aux
aux vs 30 pin
iphone 30 pin connector vs 3.5mm jack
is the 30 pin connecter better for audio than 3,5 mm
