Will a skin cause any problems over the 3G antenna?
This is a discussion on Will a skin cause any problems over the 3G antenna? within the iPad General Discussions forums, part of the Apple iPad Discussions category; This is probably a dumb question, but I just wanted to make sure and I did a search (a few with different key words) and ...
Results 1 to 4 of 4
    37343
    LA
    24
    This is probably a dumb question, but I just wanted to make sure and I did a search (a few with different key words) and didn't see anything about this.
    I'm sure it's really no different than putting your 3G iPad into a fully enclosed case, but is there any reason why I should not put a skin (the peel & stick ones) on the back of a 3G iPad, covering up the 3G antenna black bar on the back side?
    Banned
    10565
    16 times
    Jul 2010
    Va
    1,251
    It shouldn't make any difference unless it's super thick or made out of some material that'll mess with radio waves.
    10986
    2 times
    Jul 2010
    Birmingham, Al, USA
    322
    I had a skin on my first iPad for quite a while. Now I have a newer iPad and it already has one (see avatar) and I haven't noticed any issues.
    116 times
    15,249
    I have the regular Apple case and there's no issue. All of the skins are non-metallic, so there's unlikely to be any problem. More of an issue is whether you're trying to use the iPad inside your car (metallic) or behind a serious obstruction (hill). Furthermore, the iPad and the 3G/GSM/CDMA basestation (aka cell tower) adjust their power output dynamically to compensate for signal attenuation.
    Enjoy your iPad and have fun.
  1. Over-the-air TV Antenna for iPad
    By xune in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-21-2012, 01:55 PM
  2. TPU Skin
    By T6D16C84 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 01-05-2011, 07:32 PM
  3. Finally: got my 3G antenna to work..
    By Wetstuff in forum iPad General Discussions
    Last Post: 09-19-2010, 10:41 AM
  4. antenna positioning effects on the ipad, ala iphone4
    By monkeyboy in forum iPad General Discussions
    Last Post: 07-04-2010, 11:13 PM
  5. Apple hiring antenna specialists
    By Seadog in forum iPad General Discussions
    Last Post: 06-30-2010, 04:56 PM
3g aerial for ipad
can you cover antenna on ipad
coach ipad cover antenna issues
ipad 2 3g antenna location
ipad 2 3g cell antenna location
ipad 3g antenna
ipad antenna location
ipad cover 3g antenna
what is the black bar on the back of a 3g ipad for
where are 3g antenna location on the ipad 2
where is the ipad antenna located
will a skin mess up the 3g on the ipad back
