Will MicroSIM card work in a laptop as an aircard?
This is a discussion on Will MicroSIM card work in a laptop as an aircard? within the iPad General Discussions forums, part of the Apple iPad Discussions category; Forgive me if I am using the incorrect terms...LOL Currently I have a Dell laptop with an AT&T 3G Sim/air card, and the $60/mth plan. ...
Results 1 to 10 of 16
    2858
    Apr 2010
    Fort Lauderdale, FL
    87
    Currently I have a Dell laptop with an AT&T 3G Sim/air card, and the $60/mth plan. I'm thinking about getting an Ipad. Obviously the sim in my laptop won't work in the Ipad, since it's a standard sim. Besides that, I'm paying $60/mth for it, so I'd rather get the $30/mth Ipad/ATT plan. If I got an adapter for the microsim, would it work in my laptop, since they're both AT&T, or am I SOL?
    1596
    164 times
    Mar 2010
    4,563
    This is a sticky one I have heard you can cut the sim to make it fit but then you cannot use it in the laptop I cannot answer this one over to Max or some one else
    2858
    Apr 2010
    Fort Lauderdale, FL
    87
    Thanks for the reply, but I'm actually trying to find out the opposite of what you said.....I want to get the new $30 plan for the Ipad, and then get a mirco sim adapter (to make it full size) and use it in my laptop. I'm hoping to see if they micro sim and the $30 plan will work in the laptop, or would it only work in an Ipad? That way I can cancel my current $60/mth plan, and just have the $30 plan, and use the sim in both things. I hardly ever use my current air card anyway, so it's been hard to justify the $60 a month I've been spending.
    1583
    50 times
    Mar 2010
    Oklahoma
    2,524
    Theoretically, it should work. OTOH, how would you get to the micro sim on the iPad? As I understand it, it is built into the unit and all you do is activate it. It is not a item you can get from the AT&T store.
    1583
    50 times
    Mar 2010
    Oklahoma
    2,524
    I did some research and it does appear that the micro sim is removable. So if you get a card adapter, you can try it and see if it works.
    2657
    Apr 2010
    California
    29
    Quote Originally Posted by Seadog View Post
    While I hope this works it is most likely that the AT&T system will require the SIMM to be in the device that it is registered to (IMEI number) in this case the iPad....but you never know
    iPad Master!
    1497
    Mar 2010
    South Florida
    596
    I see where your going with this smarty. Unlimited data for $30 on your laptop. I guess we won't know until these things roll out, but, I would imagine the big greedy att probably did something special to these sims to only work on the ipad. If not then smart guys like you will get a pretty cheap data plans available to them.
    2858
    Apr 2010
    Fort Lauderdale, FL
    87
    LOL
    I'm not trying to get anything over on AT&T. Hell, I've been paying the $60/mth to them for about a year and a half now, and literally I've used it maybe 10 hours, if that. I just don't see the point of having another $30/mth subscription for a 2nd device, while still paying for the first one that I hardly use.
    I figured out what I'm going to do. I already ordered a 3g Ipad, and I'm going to activate the $30 plan with it. I'm going to get the adapter to make it a full sized sim, and try it in my laptop. If it works, then great. If it doesn't work, I'm going to cancel both plans and get a MiFi, and just run everything off the MiFi using Wifi. Then I'll at least be saving a few dollars instead of spending 90 bucks a month.
    Thanks y'all for the replies
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    I agree that it should be illegal to charge twice for the same service on different devices! You should be able to use it on one at a time!! So if you already have a data plan for your iPhone you should be able to go online and switch it to the iPad and vice verse.
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Quote Originally Posted by spinfreak View Post
    LOL
    That would however mean you waited an extra month and spent an extra $130 for nothing.
  1. KELLNER: Apple's new iPad not yet ready to replace laptop
    By 4phun in forum User News Submissions
    Last Post: 04-14-2010, 06:44 PM
  2. Timbuk2 Laptop Sleeve
    By scarrz in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-05-2010, 10:01 AM
  3. Will we see an tablet that is effectively a laptop?
    By ipad987 in forum iPad General Discussions
    Last Post: 04-02-2010, 01:43 PM
  4. Can the iPad replace the desktop or laptop?
    Last Post: 03-23-2010, 08:13 PM
  5. Replies: 4
    Last Post: 02-08-2010, 02:19 AM
can i use micro sim in laptop
how do you put a micro sim in laptop
ipad sim card in laptop
laptop using microsim
laptop with micro sim
micro sim aircard
micro sim in laptop
microsim and laptop
microsim for laptop
sim card from aircard in ipad
use ipad sim card in laptop
using ipad sim in laptop
