Originally Posted by
nateccnn
What if I store the file on Dropbox and then tell Goodreader to save it to Dropbox? Then when I open it in PDF Expert it has the notations.
Is that even an option? I'm not near my iPad to give it a try right now.
Nate
Edit: That won't work when I want to switch back and forth while flying. Doh!
You folks need so lessons in how PDFs work.
And yes I can share annotations between devices and platforms.
The best tools are
DropBox
GoodReader
IAnnotate
Jolliprint (used from Safari).
Adobe's Acrobat Reader X on windows 7
Preview in OS X
Other lesser tools
Notability
Pages
QuickOffice
Don't fool with too many PDF tools on the iPad or you will run into OPEN WITH... Problems.
I think the limit is ten.
Annotations are stored in a second hidden file that must be transferred. Barring that the only other choice is to FLATTEN THE PDF to send device independent markup and high lights. Some poorly written schemes flatten PDFs by creating images of the Annotated PDF - bad news if you need to work with text.
Here is some info from iAnnotate update
What's New in iAnnotate
Posted by Dev Team on 07 January 2011 09:13 PM
Version 1.4 of iAnnotate adds:
Annotation
Typewriter annotations: add editable text notes directly on the PDF page. adjust font, size, color, justification, and rotation
Typewriter w/Today's Date: instantly insert the text for today's date (for example, for signature forms)
Includes the ability to create stamps out of typewriter annotations
Thickness and transparency for Ink annotations (allows free-form highlighting non-OCR documents)
Vector eraser for Ink annotations
Ability to view several more kinds of existing annotations (including callout, line, caret, etc)
Ability to directly import image files into the stamp library
Interface
Single-Page mode: optional setting to display only one page at a time (similar to iBooks), with swipe/slide or tap to turn pages
Improved Document search: proper handling for phrases, punctuation, and even regular expressions.
Page scrollbar now available in Go-To-Page (useful for large documents)
Integrated dictionary, Wikipedia, and Google lookup of selected text
Forward/Back navigation (esp useful in a document with links)
Next/Previous annotation, bookmark, and outline element toolbar buttons
Fit-to-width and fit-to-height toolbar buttons
Ability to drag/move the popup annotation editors
General
Improved handling of existing annotations (most existing annotations are now editable)
Improved handling of multi-column PDF
Many bug fixes and minor interface improvements
NEW: Experimental Features
These are high-demand features that we have developed for the iAnnotate user community to try!
Still in a "beta" phase, so some unusual or unexpected behavior may occur. Any feedback is greatly appreciated.
Ability to save a webpage as a (vector) PDF file: store webpages for later reading, searching, and markup
Ability to import Word (DOC/DOCX) and PowerPoint (PPT/PPTX) documents as PDF files
Version 1.3.2 of iAnnotate adds:
Updated for iOS 4.2
In-app printing support
Ability to "Flatten" annotations into PDF page content, including end notes for all text popups/comments
Ability to email only annotated pages of a document (in flattened or normal form)
Significant improvement in handling drawing and processing of very large PDF files
