Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 61
    2699
    Apr 2010
    united kingdom
    21
    Ipad initial set up after unboxing-is it dead?PLEASE HELP
    Hello
    I ve bought a brand new sealed ipad in my last trip in the US and i was really glad that i did so.
    i plugged the ipad in my mac book pro(after having updated it to meet the specs for ipad) and the ipad is in recovery mode(as it is supposed to be) and nothing is happening(usb cable icon facing the i tunes icon)
    Summary, the ipad isnt recognized at all. i restarted both pieces, but they can not see each other. Itunes has the latest update (9.1)
    I ve tried eveything, different usb ports, restarts, reinstall itunes, use different computer, reset ipad but the ipad still the same-CAN NOT SET IT UP-
    usually that would take 2 sec, just plug it and i tunes will come up automatically
    On the other side, every time i plug the ipad with the charger it starts with the apple icon on the middle of the screen, the the recovery mode and does one ping(which means that power goes in)
    I am really in a bad mood and i feel that i did everything
    Can anyone advise please?is it dead?
    Would appreciate any thoughts- here in the uk apple stores can not support-they keep saying item is not released, and sorry we are not trained to solve problems.
    Many thanks
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    If your on a mac you can take screen grabs with shift+cmd+4 it might help if you show screens of what's happening when you plug it in.
    2699
    Apr 2010
    united kingdom
    21
    Quote Originally Posted by gentlefury View Post
    i have made some pictures
    1st: my mac book specs
    2nd: itunes latest version
    3rd: ready to plug into mac book
    4th: plug ipad to mac book
    5th: opening ipad(apple icon in the centre)
    6th: ipad on recovery mode
    7th: no reaction in my mac book-doesnt do anything(it should have started automatically itunes)
    Will send remaining 2 pic in a separate post(5 pic max)
    Attached Thumbnails Attached Thumbnails Ipad initial set up after unboxing-is it dead?PLEASE HELP-screen-shot-2010-04-17-22.07.23.jpg   Ipad initial set up after unboxing-is it dead?PLEASE HELP-photo.jpg   Ipad initial set up after unboxing-is it dead?PLEASE HELP-photo-4.jpg   Ipad initial set up after unboxing-is it dead?PLEASE HELP-photo-5.jpg
    2699
    Apr 2010
    united kingdom
    21
    Last 2 pic
    Any help??i am so badly desperate to set it up-have spent hoursss with no luck
    thanks
    Attached Thumbnails Attached Thumbnails Ipad initial set up after unboxing-is it dead?PLEASE HELP-photo-2.jpg   Ipad initial set up after unboxing-is it dead?PLEASE HELP-photo-3.jpg
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    What does iTunes look like tho?
    2699
    Apr 2010
    united kingdom
    21
    Itunes doesn't open at all gentlefury(left column does has at all devices (usually when i plugged my iphone a devices category comes up and below iphone)
    and if i open it then a screen shot is here
    Do yoou have any idea what is happening?i am loosing my patience and i want to cry
    Attached Thumbnails Attached Thumbnails Ipad initial set up after unboxing-is it dead?PLEASE HELP-screen-shot-2010-04-17-22.36.14.jpg
    1596
    175 times
    Mar 2010
    4,625
    1) Hold buttons sleep + home untill
    iPad turns off;
    2) Open iTunes;
    3) Hold home button and plug the ipad
    to your computer. The ipad will turn on
    and the iTunes + Arrow + cable screen will appear.;
    4) iTunes will recover your ipad from
    unsuccessful recover
    This should work as it does with iphone. It forces a restore like back to factory. Then registratiom should work. Let me know result
    Colin australia
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Quote Originally Posted by col.bris View Post
    iPad turns off;
    2) Open iTunes;
    to your computer. The phone will turn on
    Colin australia
    Should work the same as iPhone.
    1596
    175 times
    Mar 2010
    4,625
    I am on my iPhone as computer being used by family. One reason of many why I can't wait for ipad so it's hard doing support lol The iPhone and ipad share same is OS so above should work This is how I have fixed several iPhones hope it does the job col down under
    Apple support specialist
    2699
    Apr 2010
    united kingdom
    21
    iPad turns off;
    2) Open iTunes;
    Colin australia
    Colin
    I have done as you said
    Nothingggggg-step 4 from your guidelines doesnt follow-until step 3 everything was ok but the ipad now has the itunes+arrow+cable screen constantly.....
    and you mentioned as well unsuccesful recover?why is that?bought it brand new and i just plugged it to set it up for the first time-
    i am loosing my mind as well
  1. Initial battery Charge?
    By Ellie in forum iPad General Discussions
    Last Post: 04-02-2010, 08:39 PM
  2. First iPad unboxing hits the web!
    By iDan in forum Apple iPad News
    Last Post: 04-02-2010, 09:34 AM
  3. First IPad Unboxing Video!
    By CGuglielmo in forum iPad Reviews
    Last Post: 03-31-2010, 10:35 PM
  4. iPad Unboxing Video!
    By AppHut in forum iPad General Discussions
    Last Post: 03-29-2010, 05:28 AM
  5. Initial Accessories Pricing
    By mikerm in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-23-2010, 06:52 PM
apple ipad please show where you plug it in.
cant complete setup with new ipad
help cannot set up ipad
how to initially turn ipad on
how to initially turn on ipad
initial ipad set up
ipad 2 initial screen
ipad arrow and itunes
ipad arrow itunes
plugged up ipad
setup ipad without itunes
when i turn on ipad 2 it says plug to itunes
