Ipad applications do not work
This is a discussion on Ipad applications do not work within the iPad General Discussions forums, part of the Apple iPad Discussions category; My ipad applications will not fully execute, then shut off. For example, when i activiate my email the first page begins to populate then without ...
Results 1 to 5 of 5
    33777
    Feb 2011
    Atlanta, GA
    My ipad applications will not fully execute, then shut off. For example, when i activiate my email the first page begins to populate then without warning it shuts off and i am back of the main page. The same thing happens with virtually every other application.
    Has this happened to anyone? if so, can you recommend a fix or solution?
    Thanks in advance.....
    Longhorn
    116 times
    15,249
    Is this a new problem or have you had this issue ever since you had the iPad. If it's a new problem then the usual 'fix' for this (and a range of other 'unexplained' problems) is to completely turn off the iPad (rather than putting it into 'sleep' mode, which is what most people do).
    I'm sure you know how to completely turn it off but just in case....
    Press *and hold* the 'Power' button until slider control appears on the screen asking whether you really want to switch the iPad off. Accept by sliding the control and a rotating white 'bezel' appears as the iPad powers down. This takes about 10 seconds. Once the screen has gone completely blank turn the iPad on again. Press *and hold* the 'Power' button until a white Apple icon appears. The iPad is now powering up. This takes about 10 seconds. During the power up process the white Apple icon stays on the screen but the automatic screen orientation is disabled, so don't panic! Just before the power up is complete, the iPad plays a little 'jingle' and then you're back to your 'Home' screen.
    Don't have any concerns about this 'power down' and 'power up' procedure, it's completely 'normal' and, in any case, if you go the Apple web site you'll see that they recommend that you do this about once a week in any case. Many Forum members, too, always completely switch their iPads off when they've finished using them, rather than putting them into 'Sleep' mode.
    See whether this fixes your problem. Most Forum members have found this procedure to be a good first step to fixing problems with the iPad - it's no more than 'rebooting' your PC, which most of us do if anything 'unusual' happens.
    If the problem still persists, don't hesitate to get back to us; I'm sure that Forum members will have some other ideas.
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    Quote Originally Posted by Longhorn View Post
    The iPad OS will automatically shut down any app when it detects that it's consuming too much system resources, e.g. RAM is running low.
    If you have a persistent problem running apps, turning it off and on by holding down the sleep/wake button for 10 secs (as described above) should fix it. If not, you can reset it as well -- iPad: Turning on/off and resetting
    32GB WiFi
    33777
    Feb 2011
    Atlanta, GA
    Thanks for your responses. Rebooting the iPad appears to have worked.
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    [ame]http://www.youtube.com/watch?v=QpmLrz_lSuE[/ame]
  1. re-install applications to my new ipad
    By Fahad in forum iPad FAQ
    Last Post: 11-03-2011, 04:06 PM
  2. How many Applications/Game on Your iPAD
    By peled in forum iPad General Discussions
    Last Post: 12-31-2010, 03:30 AM
  3. iPad Applications
    By casesipad in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 11-15-2010, 07:00 AM
  4. How to manage applications in iPad?
    By v1corumantir in forum iPad General Discussions
    Last Post: 11-11-2010, 12:48 AM
  5. iPad applications
    By ashishmonga in forum iPad General Discussions
    Last Post: 09-24-2010, 02:10 AM
app icon does not open
facebook app blinks but will not work on ipad
ipad app clickrun wont work
ipad app does not work
ipad application does not execute
ipad application not working
ipad apps does not work
my app does not work on ipad
what do i do when an app does not complete install on my ipad
what does it mean when apps on ipad dont work
what to do if a ipad app does not work
why does my ipad turn off when i am on my ipad, and its always facebook
