Battery Test
This is a discussion on Battery Test within the iPad General Discussions forums, part of the Apple iPad Discussions category; Well a VERY long day at work has given me a good gauge of true battery life. My iPad is running almost all day playing ...
Results 1 to 9 of 9
Thread: Battery Test
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Battery Test
    Well a VERY long day at work has given me a good gauge of true battery life. My iPad is running almost all day playing videos, checking emails, and surfing the internet. My iPad has been being used since 7:15 this morning and it is now 12:30 am and I still have 14% battery left.
    The 10 hour barrier has been shattered and I'm moving into 16 hours usage today. Shouldn't be a problem on any flight...even international
    Max
    Max is offline
    455
    57 times
    Feb 2010
    San Francisco, CA
    345
    Yup, i had a similar experience where I went 12 hours and still 37 percent left!
    Its awesome!!
    http://www.ipadforums.net/signaturepics/sigpic455_4.gif
    iPad Enthusiast!
    1699
    Mar 2010
    Leeds
    50
    What brightness have you both had you ipad on
    am just waiting for thr big brown van now and I live in the uk !!!!!!!
    iPad Master!
    1497
    Mar 2010
    South Florida
    596
    I had a feeling the battery life would keep getting better once you guys ran a few charge cycles through the ipad and allowed the batteries to get conditioned.
    iPad Enthusiast!
    2440
    Apr 2010
    32
    I too am having nice long batt days doing everything from writing to porn watching....I am guessing 14hrs maybe.
    iPad Junkie!
    2107
    Apr 2010
    183
    Hahaha. I have my brightness level all the way up just to test it out and its at 71% for 4 hours. I just lowered it..
    Proud owner of a 32gb iPad
    Owned iPhone 3G
    Owned iPhone 3GS
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Battery level is set to auto, and the slider is at about a little under 50%....it is bright enough to see everything fine, and also gives it extraordinary life.
    Something else I have noticed is that since I have gone thru a few cycles and got the lithium better conditioned I actually seem to have a bit of a reserve above 100%.
    I plug it in at night so in the morning when I wake up its at 100%...well it takes about an hour to get to 99% So it seems to actually be fully charged at about 112% give or take. Even cooler!!
    Never actually had a device that exceeded the reported battery life!
    Oh yeah, another really cool tip.....if you have an AV cable it also has a charger so if you want to watch movies on it played thru speakers it will be plugged in the whole time, so you can crank the brightness to full, movies look so spectacular when brightness is cranked!
    iPad Junkie!
    477
    Feb 2010
    Dublin, CA
    111
    Thanks for the reports you guys. That is actually really helping me reinforce my decision to get one of these babies. I have been having trouble justifying the expense due to some financial issues of my own so every little bit of justification helps.
    iPad WiFi+3G, 64GB
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Quote Originally Posted by dennis View Post
    Well the battery life is such a triumph because you don't have to carry a cable out with you! You just need it at home or the hotel or whatever...but it is so robust that you don't have to restrict what you do on it to last the day....even the longest of days will be fine.
    I got 16 hours and still had 14% left...so technically that means I still had about 2 hours left! So 18 hours total life is pretty amazing! That means with normal none abusive use the average person should only have to charge once every 3 days.
  1. Speed test Ipad vs iphone3gs
    By Pogi-pad in forum iPad General Discussions
    Last Post: 05-21-2010, 02:07 PM
  2. iPad Screen Scatch Test
    Last Post: 04-09-2010, 10:46 AM
  3. Battery Replacement
    Last Post: 03-07-2010, 09:11 AM
check battery cyccles ipad
check battery cycles ipad
check ipad battery cycles
find battery cycles ipad 2
how to check battery cycle on ipad
how to check ipad battery cycle
how to check ipad battery cycle and condition
how to check ipad battery cycles
how to see how many cicles on the battery ipad
how to tell battery cycle ipad
how to test battery cycle ipad 3
how to test ipad battery
