Wifi problems with both iPhone and iPad
This is a discussion on Wifi problems with both iPhone and iPad within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hello, I have one iPad and two iPhones. Every 10 minutes or so, they lose connection with my router. I need to go to settings ...
Results 1 to 6 of 6
    29592
    Portugal
    11
    Hello,
    I need to go to settings and turn off and on wifi to be able to have internet again.
    I have an Hitron BVW 3653 that I must use because it's specifically design to my service provider (ZON Portugal).
    Do you have any idea on now to avoid this situation? It's really anoying!!!
    Eros
    1523 times
    Walla Walla, WA
    15,432
    Well, there is a rather awkward way. You get another router that you know is compatible, hook it into one of the ethernet ports on your main router and set up a separate WiFi network for your iDevices.
    I do something similar. I have an old AirPort express. I plugged it into my iMac's ethernet port and shared my internet connection to it. Took a little fiddling to make it work, but works great.
    3279
    Apr 2010
    nc
    23
    Its a shame you cant get a new router, but check you have all the correct settings needed using apples recommendations:
    iOS: Recommended settings for Wi-Fi routers and access points
    Good luck, I know how much of a pain it is, had the same with a Belkin N+ router and I ended up buying a different brand!! Life is good again!
    18578
    9 times
    Oct 2010
    Virginia, usa
    608
    First, unplug your router/wifi device(s) and leave them off of at least 8-10 min. Then, second - Try this, go into SETTINGS - GENERAL - NETWORK, then chose the line with your network name on it and then press the blue arrow on the right, then tap the FORGET THIS NETWORK button at the top of the page. Then setup your network again. OR, you can try to tap RENEW LEASE and see it that helps. The first option above is the best one to try, as it resets everything in the network settings.
    Things to try on iPad for wifi problems.From Apple forums.
    1) - Set router to fragmentation=2048, RTS=512 an
    02) - Disable router 40Mhz, use only 20Mhz
    03) - Change router from 5 Mhz to 2.4 Mhz
    04) - Disable N router standard
    05) - Use WPA or WPA2 (2 seems better) instead of WEP
    06) - Use TKIP instead of AES or BOTH security in router
    07) - Disable bluetooth in iPad
    08) - Check nearby routers for channel conflict
    09) - Router firmware update
    10) - Reset/cold boot router
    11) - Reset network settings on iPad
    12) - Cycle iPad power off and on (fails on wake from stby)
    13) - Redownload adn reinstall the 4.2.1 update
    14) - Set iPad DNS to 8.8.8.8 & 8.8.4.4 (Google DNS?)
    15) - SetiPad autobrightness to off or away from lowest setting
    16) - Assign iPad a fixed IP address (don't use DHCP in router)
    17) - Turn off "ask to join networks" on iPad
    18) - Turn off notifications iPad
    19) - Adjust QOS (google for settings)
    20) - Change the passwords for your main and guest networks in Apple Extreme and update to latest firmware
    Good Luck
    Pocobear
    29592
    Portugal
    11
    Thank you guys!! I think I found the problem; I was using an SSID with a space on it, now i entered an underscore between the two names and everything's working fine. My fault on this one!!
    25987
    Dec 2010
    USA
    423
    Quote Originally Posted by erosnunes View Post
    Thanks for letting us know. I was still trying to figure out which way to point you. Glad you are up and running again.
    iPad 32GB + 3G
    iPad 16GB
    iPhone 4 16GB
    iPhone 3GS 8GB
    OtterBox cases on all
    Sent from my iPad while riding my BMW K1200RS listening to my iPhone 4
  1. iPad 64GB WiFi problems (cannot connect)
    By BikerThomas in forum iPad Help
    Last Post: 12-27-2011, 03:53 AM
  2. Ipad has serious wifi problems
    By FatalDesain in forum iPad General Discussions
    Last Post: 01-16-2011, 02:23 PM
  3. Wifi iPad jailbreak problems v 3.2.1
    By Saket in forum iPad Help
    Last Post: 08-23-2010, 07:09 AM
  4. Ipad wifi login problems
    By shaggy1219 in forum iPad General Discussions
    Last Post: 07-24-2010, 07:12 PM
  5. iPad Wifi Problems?
    By ayerbusiness in forum iPad General Discussions
    Last Post: 05-09-2010, 07:22 AM
how to disable qos ipad
how to disable qos on ipad
how to turn off qos on ipad
ipad monopoly wifi lost connection
ipad turn off qos
qos iphone
turn off qos ipad
turning off qos on ipad
