Battery: Running it down to 0% or charging on a regular basis?
This is a discussion on Battery: Running it down to 0% or charging on a regular basis? within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hi all I've read that "For proper reporting of the battery’s state of charge, be sure to go through at least one charge cycle per ...
Results 1 to 6 of 6
    29245
    Denmark
    Hi all
    I've read that "For proper reporting of the battery’s state of charge, be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down)."
    So do guys charge it whenever you feel like it, or really run it down from time to time?
    Dan
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    I try to let it run completely down once in a while... but probably not as often as once a month.
    13576
    1449 times
    Aug 2010
    Western NY state (USA)
    11,058
    I have found that when I run my iPad down under 10%, it gets hinky at charging time.
    I usually close all apps, turn off the iPad, then plug it in for charging. When its below 10%, instead of turning back on and then starting to charge, I get the glowing Apple icon forever. I have to fiddle with it to get it to charge (or to start to charge). And, sometimes, even though it's left overnight, it doesn't go to 100% - only about 50 - 60%.
    So, I try not to let it go below 10%...
    14887
    Sep 2010
    Ohio
    626
    The only time my battery has been close to 0% is when I used my iPad enough to drain the battery. Other than that, I'm not too worried about my meter being off a few percentage points and I'm not planning on making it a point to drain it. That gets in the way of using my iPad! Just use and enjoy your device and charge it when you get a chance. You will naturally have times that the battery gets close to empty anyhow, so why worry about making it a point to do so?
    1527 times
    Walla Walla, WA
    15,440
    Every few months, when I think about it, I set it in slideshow mode and forget it until it shuts down. Overnight works best. It's just about the only time I 'almost' complain about the battery life. Takes forever.
    iPad Ninja
    3495
    31 times
    May 2010
    Switzerland
    2,017
    Oh that reminds me! I haven't let it get that low in a while.
  1. Charging a New Battery
    By Solaris in forum iPad General Discussions
    Last Post: 11-03-2010, 09:20 AM
  2. Battery not charging correctly
    By lynda07 in forum iPad Help
    Last Post: 09-23-2010, 03:42 PM
  3. charging the battery
    By Mexicat in forum iPad General Discussions
    Last Post: 07-14-2010, 03:31 AM
  4. Battery charging
    By Seadog in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-05-2010, 09:29 PM
  5. iPad battery not charging
    By bbmountain in forum iPad General Discussions
    Last Post: 06-28-2010, 03:37 PM
ipad battety fown to zero
letting battery on ipad go to zero
run ipad battery down to zero
should i let my ipad 2 drain to 0%
should i let the battery run down to 10% ipad
should you let ipad go to 0 before charging
used ipad to 0%
what happens to an i pad when battery down to zero
