Ipad Battery
This is a discussion on Ipad Battery within the iPad General Discussions forums, part of the Apple iPad Discussions category; hello all I have a question about the charging the ipad. I have noticed that when the ipad is charging at the mains, if you ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Ipad Battery
    21914
    Nov 2010
    CHina
    11
    Ipad Battery
    hello all
    I have noticed that when the ipad is charging at the mains, if you start to use the ipad, the ipad doesnt seem to charge anymore.
    I find this strange because for example if i am charging my laptop battery whilst using it at the same time, my laptop battery is still being charged.
    But for my ipad, it just seems to stop on like 34% charged, or whatever it is at.
    is there a way around this? is this a fault?
    I am sure on my iphone that you can use the phone and it still charges at the same time.
    thank you all for your time
    25550
    Dec 2010
    Ft. Lauderdale, FL
    40
    mine charges anytime it's plugged weather i'm using it or not.
    iPad2 32GB w/3G
    iPhone 4 32GB
    Mac Mini 2.53 C2D
    20954
    Nov 2010
    Palm Springs, Ca.
    112
    Quote Originally Posted by ParishM View Post
    Same here. I don't often use it while it's charging but I have and it does continue to charge.
    21914
    Nov 2010
    CHina
    11
    do you guys find that it takes along time to charge? roughly how long does it take you guys to charge fully from about 10% to 100% full?
    23808
    Dec 2010
    LA
    11
    I dont see the situation, i guess you'd better take it to the Apple service center ...
    Last edited by iPadCharlie; 12-26-2010 at 05:36 AM. Reason: Removed link not related to topic
    19947
    Nov 2010
    361
    It takes me abut 3 hours to get 100% from 0%, sometimes longer because I us the iPad while it's charging
    iPad 2 Owner
    17954
    3 times
    Oct 2010
    N.E. Ohio
    878
    Quote Originally Posted by Gunny008 View Post
    I would say that sounds right. I'd also advise you not to run it down to zero, at least not on a regular basis.
    Lithium batteries do not have memory like the old nicad batteries so you can charge them anytime you feel like it.
    iPad Master!
    25792
    3 times
    Dec 2010
    SoCal
    417
    A quick couple questions for you:
    1. Are you charging it through a computer's USB port?
    2. Are you using an iPhone or iPod touch's charging adapter instead of the larger, more powerful charging unit that came with the iPad?
    3. Have you recently used any travel voltage/amperage adapters with your iPad?
    The iPad will still charge via USB or with chargers designed for the iPhone/iPod, however, the wattage is twice that compared to the one included with an iPhone, and has a higher amperage rating (2.1A). USB ports also work, but charge at a slower rate than using the supplied charger.
    If you using the charger that came with your iPad, and are noticing longer than usual charging times, make an appointment with your nearest Apple store's Genius Bar, where they can check it for you. Make sure you do one last sync with your computer before going, as they may replace your iPad under warranty if it indeed is not taking a charge properly.
    After my wife traveled to Europe with our iPad, upon returning to the US, we noticed that our ipad was intermittently taking a charge and/or charging very slowly - so we made an appt at our closest Apple store's Genius bar, and upon verifying the charging problem, replaced my iPad with a new one.
    I cannot tell you what they will do for you when you go and see them, as it is up to the techs that look at your device, but they have the tools and the knowhow to diagnose and troubleshoot Apple products better than anyone.
    iPad wifi + 3G w/Clear 4G iSpot
    iPad 2 wifi black w/Tan Smart Cover
    Next up.. iPhone 5!
    Mac user.
    19947
    Nov 2010
    361
    Quote Originally Posted by xune View Post
    Did you mean to quote me there?
    No to those questions...I thought 3 hours was a good amount to charge the iPad?
    iPad 2 Owner
    iPad Master!
    25792
    3 times
    Dec 2010
    SoCal
    417
    Oops, I meant to quote Romeolo888.
    Next up.. iPhone 5!
    Mac user.
  1. Battery Pack for iPad?
    By Bmosbacker in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-17-2012, 07:13 PM
  2. Tips on draining ipad battery?
    By Mv-ixius in forum iPad General Discussions
    Last Post: 01-02-2011, 10:33 PM
  3. iPad battery indicator %
    By Zanvetto in forum iPad General Discussions
    Last Post: 09-22-2010, 09:03 AM
  4. iPad battery not charging
    By bbmountain in forum iPad General Discussions
    Last Post: 06-28-2010, 03:37 PM
can i charge my i pad at anytime
can i charge my ipad in china
can i charge my ipad in china?
can you charge an ipad anytime
can you charge ipad battery anytime
charge ipad in china
charging ipad in china
charging my ipad in china
how do i charge my ipad in china
how do i charge up my ipad in china
how to charge ipad in china
ipad not charging in europe
