Why go I get "Not Charging" when the iPad is plugged in to PC's USB?
This is a discussion on Why go I get "Not Charging" when the iPad is plugged in to PC's USB? within the iPad General Discussions forums, part of the Apple iPad Discussions category; When I plug my iPad in to the USB port of my lap top, I get a "Not Charging" indication near the battery indicator? I'm ...
Results 1 to 10 of 13
    2236
    Apr 2010
    14
    When I plug my iPad in to the USB port of my lap top, I get a "Not Charging" indication near the battery indicator? I'm still living off the first initial charge through the supplied adapter but really planned on charging it via my lap top or PC.
    Any ideas why?
  2. #2
    iPad Guru
    1284
    4 times
    Mar 2010
    2,624
    not enough power to charge..it will data sync tho. You will need a double USB plug to power it and sync.
  3. #3
    965
    3 times
    Mar 2010
    Chicagoland
    406
    It looks like the iPad may actually be charging when connect via USB with the screen is off. It is just a lot slower than when plugged into wall charger though.
    Confirmed: "Not charging" iPad does recharge
    64GB Wifi iPad Owner
  4. #4
    2236
    Apr 2010
    14
    Thanks - but what's a double USB?
  5. #5
    1583
    41 times
    Mar 2010
    Oklahoma
    2,375
    What he means is a USB port that is rated at 1000mw instead of the older 500mw outlets. Most USB 2.0 ports only had a maximum rating of 500mw due to the low power requirements that most items required. The iPad is still a 5Vdc system, but to charge while it is being used, you have to pull 1000mw of power. 500mw is enough to charge a iPad when turned off, or to maintain the charge on a actve iPad. To do both, you require a 1000mw unit.
  6. #6
    2243
    Apr 2010
    NYC
    22
    thank g-d this is normal cuz i thought something was wrong with my ipad.
    but it took a long time for me to charge my ipad with the wall adatar i charged only one time and it took about 5 hours to fully charge.
    is that normal?
  7. #7
    965
    3 times
    Mar 2010
    Chicagoland
    406
    I have read that it should take about 4 hours to completely recharge. I wouldn't worry about your iPad. I am sure it is fine.
  8. #8
    1583
    41 times
    Mar 2010
    Oklahoma
    2,375
    The iPad has a relatively large battery. It may have half of its weight in the battery from what I have heard. The bigger the battery, the longer it takes to charge.
  9. #9
    iPad Junkie!
    2247
    Apr 2010
    Indianapolis
    245
    I think it also gives that message when charging is complete.
  10. #10
    iPad Guru
    1284
    4 times
    Mar 2010
    2,624
    Quote Originally Posted by Seadog View Post
    no I mean a double USB cable. It has one USB on one side and two on the other. It's for hard drives and other devices that require more power than the old USB ports allowed.
Sponsors
  1. App Store "wish list" feature...
    By Isaac Newton in forum iPad General Discussions
    Last Post: 03-27-2010, 11:04 PM
  2. First iPad "HD" games already in iTunes preview...
    By brobar in forum iPad General Discussions
    Last Post: 03-25-2010, 07:50 PM
  3. Article: "Overwhelming" Demand Limiting in Store Pickup
    By wot_fan in forum iPad General Discussions
    Last Post: 03-12-2010, 11:46 PM
  4. iPad or just an "over sized" iPod?
    By spitfire55 in forum New Member Introductions - Site Assistance
    Last Post: 02-18-2010, 09:54 PM
  5. iPad "I'll Buy It" - Theme Song
    By iDan in forum iPad General Discussions
    Last Post: 02-02-2010, 02:22 PM
burn cd
high power usb hub ipad
i pad chrging from lap top
ipad indicates not charging
ipad indicates not charging when pluged in
ipad indicates not charging when plugged to usb
ipad not charging indicator
ipad plugged in but indicator says not charging
ipad plugged in but says not charging
ipad plugged in not charging
ipad plugged into power, indicator says not charging
ipad says not charging when plugged in
ipad says not charging when plugged in usb
not charging ipad from lap
what to do if not charging
why ipad not charging when plugged into pc with usb?
why is ipad not charging usb
why is my ipad not charging when plugged in
why is my ipad not charging when plugged into a pc?
why the ipad 2 indicate not charging?
Tags for this Thread
