Help with iPad?
This is a discussion on Help with iPad? within the iPad General Discussions forums, part of the Apple iPad Discussions category; So when i have bought apps from the app store on my ipad, they work fine and everything. But then when i plug it into ...
Results 1 to 3 of 3
Thread: Help with iPad?
    23356
    Dec 2010
    Help with iPad?
    But then when i plug it into my computer i watch itunes and it says copying apps then it just says removes and removes them from the ipad, and they're not on the ipad or itunes anymore.
    Help please?
    17419
    2 times
    Oct 2010
    Texas
    646
    Make sure you are using the same iTunes account on both your PC and iPad. If it's a different one it will erase them because you didn't buy them on that other account.
    Everything is Bigger in TEXAS!!
    iPad 16GB WiFi
    iPhone4 32GB
    Be sure and check out iphone4forum.net! For anything iPhone..
    Me over on the other side...
    23356
    Dec 2010
    thanks for the reply but i am using the same account
