I've got just the 3G.
This is a discussion on Speed test Ipad vs iphone3gs within the iPad General Discussions forums, part of the Apple iPad Discussions category; I've got just the 3G....
Does the 3GS use 802.11n? I thought it only went up to .11g? If your router can be put in 802.11n only mode give that a try and see if you get any change.
Try running in 2x mode on the iPad and screen capture. That may help with the iPad image at least.
Add 202 to my user number and call me an Airplane.
--iPad 2 64 GB Black WiFi "Dynabook 2011. With know-how and integrity"
thank you for this informative post
Really cool testing guys
No need to test, lol
iphone 3g and 3gs = 802.11G
iPad = 802.11N
ipad wifi = faster than iPhone.
for those that didnt get faster speeds, were you using them both on a wireless G router? Wireless N router will give better speeds to the iPad.
you then also have to deal with the speeds and reliability of your ISP. you could perform the speed test from the same PC or device and get different speeds each time depending on the ISP, data caps, equipment, and network congestion.
