How to Turn an iPhone Into a Wireless Bluetooth iPad Camera
This is a discussion on How to Turn an iPhone Into a Wireless Bluetooth iPad Camera within the iPad General Discussions forums, part of the Apple iPad Discussions category; Video
The iPad doesn't have a built-in camera, but you can give it something better. By putting an app onto each an iPad and an ...
Supporting Vendor
Video
The iPad doesn't have a built-in camera, but you can give it something better. By putting an app onto each an iPad and an iPhone, you can connect the two via bluetooth and have a wireless camera for your iPad.
All you need to do is download the Camera A and Camera B apps onto your iPad and iPhone respectively—note that Camera A will set you back a buck while Camera B is free. Once you've got the apps on your devices, make sure bluetooth is switched on, and open the apps. Ta da! You'll see everything your iPhone's lens sees on your iPad.
To take a picture you'll tap the camera icon at the bottom of your iPad's screen. A pop up prompt will ask you if you really want to save the photo and that's it, you're done. Oh, and if you want photos to save to both your iPhone and your iPad each time, then you can flip the little toggle switch in the lower right of the screen
This sounds impressive. I could see this being used for video chats. Quality is supposedly not so great.
Source: How to Turn an iPhone Into a Wireless iPad Camera - Ipad camera - Gizmodo
04-06-2010 09:02 PM
iPad Enthusiast!
Of course I just HAD TO try this. It's amazing!
iPad Master!
PicRemoteX 1.0.0
Originally Posted by
cimousa
Video
Source:
(Photography)
from Apps (Free) for iPad
PicRemoteX 1.0.0
Category: Photography
Price: Free, Version: 1.0.0 (iTunes)
Description:
PicRemoteX is a remote camera receiver for your iPad that lets you add pictures to your iPad from your iPhone's camera or photo library. It works in coordination with the free iPhone application PicRemote, which is required in order to use PicRemoteX.
After downloading PicRemoteX onto your iPad and PicRemote on your iPhone, simply start each application and select connect in both. Choose the device to connect to on one device and accept the connection on the other. You will be alerted when you have connected on both devices. Once connected, simply take or select a picture from your iPhone and send it to your iPad, running PicRemoteX.
Both PicRemote and PicRemoteX work over bluetooth, so you will need to enable that in the settings for both devices.
PicRemoteX
Hi, Cimousa and 4phun,
a million thxs to both of you for your brillant help and even demo pics.
I've downloaded both, because now I need to get an IPhone first.
But then I'll make sure to get it to work the one or the other way !
I do appreciate your support.
Best regards
Mike
- You may not post replies
- You may not edit your posts
Forum Rules
By pcimaging in forum iPad General Discussions
Last Post: 12-14-2010, 11:14 PM
By henry2 in forum Off-Topic
Last Post: 04-07-2010, 08:15 PM
By edezube in forum iPad Accessories
Last Post: 04-05-2010, 12:32 PM
By iDan in forum iPad General Discussions
Last Post: 04-03-2010, 09:32 AM
By kilofox in forum Off-Topic
Last Post: 03-29-2010, 09:11 AM
bluetooth camera for ipad app
bluetooth camera ipad
bluetooth camera ipad iphone
bluetooth camera iphone
bluetooth camera iphone app
bluetooth video app iphone
bluetooth video camera for iphone
bluetooth video camera iphone
bluetooth video from iphone to ipad
bluetooth webcam for ipad
how to turn an iphone into a wireless ipad camera
iphone bluetooth camera app
remote bluetooth camera for ipad
turn iphone into ipad camera
turn your iphone into a wireless ipad camera
video connect two ipad bluetooth
wireless bluetooth camera for iphone
wireless bluetooth camera iphone
wireless camera for ipad
wireless camera iphone to ipad
