Router, need help
This is a discussion on Router, need help within the iPad General Discussions forums, part of the Apple iPad Discussions category; I have B model and few years old. I'm still getting good Internet connection but I would like to improve the video quality when streaming ...
Results 1 to 10 of 17
    10163
    Jul 2010
    Las vegas
    114
    Router, need help
    I have B model and few years old. I'm still getting good Internet connection but I would like to improve the video quality when streaming with apple tv and netflix. What N router can you recommend that will also support HD streaming? There are 3 computers, iPhone, iPad and an apple tv in the house, thanks
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    If it is strictly for home use, there is really no need to spend a lot of money for an 802.11n router. I have a D-Link DIR615 which is (was?) their entry level (read: cheapest) routers and it works great at my house.
    22364
    Nov 2010
    Central California
    9
    May be a little off, but unless your router is having problems, may want to look at your modem first to ensure it is sending the signal at the designed speed, also you may want to see if you can get a faster download speed from your carrier. Movies to be smooth need speed of download. After that, a mid ranged router seems to work well. I use a linksys which I have never had any problems with, this is connected via a motorola modem -DOCSIS 3.0. Great smooth internet for movies and gaming.
    TJK
    Guest
    I just a new Netgear n600 and am really happy with it. Streaming is much smoother than with my older G router. We've got 2 Macs, 2 iPads, 2 iPhones, Apple TV - all connected wirelessly- and a couple of win 7 laptops and this thing is rock solid. We also have it connected to a 1TB network drive and the USB port to connect an older HD.
    WNDR3700
    10163
    Jul 2010
    Las vegas
    114
    Thanks guys. Now I can take the steps you've given to check my Internet strength. I will check with my provider (cox cable) my Internet speed. Since my router is an old model I will just upgrade it.
    11187
    Aug 2010
    NJ
    109
    Quote Originally Posted by TJK View Post
    WNDR3700
    TJK....I just picked up a 32G I-PAD wi-fi Friday and need a router now....previously used wired for the PC's. I see the CISCO Valet-Plus written up a lot as well as the WNDR3700.
    Was the WNDR3700 easy to set up?? Thanks Ken
    22364
    Nov 2010
    Central California
    9
    If you are looking at routers around the $100 dollar mark, take a look at Linksys E3000 or the E2000. I have some history with both.. They are easy to set up, if you want to do more advanced stuff, the interface menu's are easy and I have never had any issues with tech support.
    Both have a 300 Mbps so your wireless will stream very fast and run movies like a wired connection as long as your provider has you on a plan that can utilize the speed.
    iPad Junkie!
    10350
    Jul 2010
    California
    124
    Quote Originally Posted by SteamBMW View Post
    I also have the E3000, it is easy to set up and works flawlessly with my iPad and other wireless devices.
    Money grows on the tree of persistence.
    7488
    Jun 2010
    189
    whatever you do, stay away from the WRT120N. I cannot get an N connection on it with anything. I've ordered the D-Link Wireless Xtreme N router based on very high owner ratings.
    TJK
    Guest
    Quote Originally Posted by Kenworth View Post
    Setup was painless and it has worked flawlessly since.
  1. Router upgrade
    By Stevekw in forum iPad Help
    Last Post: 11-16-2010, 08:36 AM
  2. Router?
    By HUNTER1 in forum iPad General Discussions
    Last Post: 09-04-2010, 08:39 PM
  3. Wi-Fi router recommendation
    By chisaki in forum iPad Help
    Last Post: 07-26-2010, 05:24 PM
  4. Wireless router
    By whoachubby in forum iPad General Discussions
    Last Post: 07-07-2010, 01:22 PM
  5. Best portable wifi router on ATT
    By CPMS in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-13-2010, 03:58 AM
cisco e2000 apple tv
cisco valet plus apple tv
i pads 2 connect to n600 router
linksys e2000 apple tv
linksys wifi n600 issues with ipad
netgear n600 and apple tv
netgear n600 apple tv
netgear n600 ipad connection
