Slow Backup via Itunes - How to Speed up>?
This is a discussion on Slow Backup via Itunes - How to Speed up>? within the iPad General Discussions forums, part of the Apple iPad Discussions category; I'm finding that the backup's are taking Too long. Being new to I-tunes is there an easy way to tell it not to backup the ...
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 57
    iPad Enthusiast!
    1585
    Mar 2010
    Palo Alto Apple Store
    74
    I'm finding that the backup's are taking Too long. Being new to I-tunes is there an easy way to tell it not to backup the device and or to limit what it backs up?
  2. #2
    iPad Enthusiast!
    1585
    Mar 2010
    74
    Ok - looks like you can click the X and it will stop the backup and continue with the sync.
    Have no idea why the backup is taking so long (in excess of 10 minutes) - and its not even backing up the media.
    So far the only thing I dislike about the Ipad is the Itunes!
  3. #3
    145
    Jan 2010
    Wheaton, IL
    21
    I am having the same frustration. Took nearly an hour last night, and I'm about twenty minutes into one this morning and less than half done. I'm wondering if it might just be the number of new iPads and itunes server capacity. May go away as a problem when the traffic slows down a bit. Just a guess. Currently very frustrating!!
  4. #4
    iPad Guru
    1284
    4 times
    Mar 2010
    2,624
    in itunes on the front page select manually manage music and video, and on each tab just check which things you want it to sync. I like contacts and notes and all my data, I also like to sync apps so I can organize on iTunes and also keep them in case something happens. Its best to manually sync movies and music tho..that way you can just drag and drop what you want.
  5. #5
    iPad Enthusiast!
    1961
    Apr 2010
    35
    With the iPhone and now with the iPad, this can be an occasional problem. usually it is related to one particular app. With the iPhone I experienced this with ESPN's original app. When it came out, it killed the backup process. I finally removed the app until they fixed it and that resolved the problem. Likewise, in the first few days with the iPad I experienced a slow backup. The first thing I did was remove ESPN XL. But this time it was not their fault. Before I could go through the process of figuring out the culprit, they (and I cannot remember who "they" was) released an update. I saw it on the release notes that it corrected an issue with backups. Sure enough after installing, the problem was resolved.
    So in the short term, you can always x out of the backup. Though I would recommend letting it complete when you have the available time to let it sit. Then either go through the process of elimination to determine which app is causing the problem. Or sit tight until the app gets fixed, and make sure that you install updates as soon as they are released.
    Hope this helps.
  6. #6
    2231
    Apr 2010
    Denver, NC
    13
    Thumbs down
    Quote Originally Posted by CGPanama View Post
    Hope this helps.
    How are people supposed to know when an app is updated, other than to check its iTunes page every day (asking legitimately, not angrily. I've never owned a touch iPod/phone long enough to figure that out... And the iTunes help doesn't mention it at all)? I did the "check for updates" thing in the apps section of iTunes, but it said there were none... But then I went to look up all the horrible reviews for the broken Abc app, and it said they had released a new update... I had to manually reinstall.
    This of course is after suffering the same stupid backup wait times that led me to finding this single thread on google the other day. I'm starting to get pretty frustrated, when my iPod video takes 60 seconds to sync, and the iPad sync times are completely unpredictable... I never checked a box saying that I wanted to backup anything. If it means I have to wait on it all day, I'd rather lose everything on the iPad than have to backup.
    Why not, the thing can't even remember my wifi password for more than 24 hours as it is...
  7. #7
    2777
    Apr 2010
    8
    Mine remembers my wifi address plus 30+ wifi addresses... But yes, my ipad tends to forget those cheap b/g/ entry level routers tho.... Even with N, my ipad tends to lose the connection time to time, if i'm too far away from the access point
    Quote Originally Posted by MattChance View Post
    Hope this helps.
  8. #8
    iPad Enthusiast!
    3889
    May 2010
    Philippines
    69
    I don't see the reason why your back up is very slow because as for me, it really works perfectly. I can download music from itunes very fast and I do not have any problems about it.
  9. #9
    iPad Enthusiast!
    3899
    May 2010
    NYC
    51
    In iTunes, go to Library, and then Apps. To the right of the word "apps" there will be a number if there are any updates available. Also, after clicking on the "apps" to show all of your apps, in the lower right corner, it tells you how many updates are available. You don't need to check each one individually.
    And out of curiosity, why do you sync all the time anyway? I don't sync that often on my iphone or ipad.
  10. #10
    iPad Master!
    3239
    Apr 2010
    Missouri
    404
    Not sure why some are having the backup issue, but mine takes maybe two minutes max to backup, and yet my son's took an hour last night! There are times
    I sync several times a day, and it's never taken more than two minutes. And that is with gigs of music and maybe 70 apps.
Sponsors
  1. iPad Backup Syncing taking Forever!
    By chipzip in forum iPad Help
    Last Post: 10-03-2011, 03:16 PM
  2. iTunes 9.1 is now up!
    By brobar in forum iPad General Discussions
    Last Post: 04-01-2010, 12:39 PM
  3. iTunes 9.x
    By KiltedTim in forum iPad General Discussions
    Last Post: 03-25-2010, 12:12 PM
  4. iPad to review and backup SD memory cards for photography travel
    By MarathonMax in forum iPad General Discussions
    Last Post: 03-18-2010, 01:17 PM
  5. Need For Speed - iPad Demo
    By iDan in forum iPad Games
    Last Post: 01-29-2010, 12:31 AM
backing up ipad slow
backing up ipad takes too long
how to speed up ipad sync
ipad backup slow
ipad backup taking forever
ipad slow backup
ipad sync slow
itunes backing up slow
itunes backup slow
itunes backup takes forever
itunes backup takes too long
itunes backup taking forever
itunes slow backup
slow ipad backup
why does ipad backup take so long
why does ipad take so long to backup
why does ipad take so long to sync
why does it take so long to back up my ipad
why does it take so long to backup my ipad
why does it take so long to sync my ipad
