Has anyone found an app similar to MyMobiler (for windows phones), that would allow me to remote control or just even view my ipad screen from my windows or Mac Desktop?
I did do a search and could not find such an app.
This is a discussion on Need to remote control my Ipad from my desktop within the iPad General Discussions forums, part of the Apple iPad Discussions category; Has anyone found an app similar to MyMobiler (for windows phones), that would allow me to remote control or just even view my ipad screen ...
You can use a vnc viewer on a jailbroken device. No way that I know of on a stock one.
Everything is Bigger in TEXAS!!iPad 16GB WiFi
iPhone4 32GB
Be sure and check out iphone4forum.net! For anything iPhone..
Me over on the other side...
I used vnc ages ago very good
we are all noobs at 1 thing or another but if I can help a fellow noob that's good enough for me.
You might want to take a good look at Logmein Ignition app. It is expensive for an app, but LogMein has a good history, it is simple to use and all the reviews are good.
Does anyone know of an app that doesn't require your desktop/laptop to be turned on to gain remote access?
Not USE, just Gain Access. And yes, this is possible, however not usually done. Some motherboards and some laptops allow for a signal to be sent through the ethernet cable to Wake On Lan. We have some lap PCs set up like this however we rarely need to utilize it.
As far as Apps go, I dont know if any would be able to kick off a Wake On Lan signal on a computer.
