I can run Veency on my iPhone just "fine" but it won't work right on my iPad 4.2.1. The mouse pointer does not function on the iPad, but does on iPhone. Right click is home button, etc.
But I would not call the performance very acceptable. Screen draw time is painful. I mainly use it with my iPhone 4 so I can text without having to pickup my phone, and to use my PC's kayboard.
Michael
I don't know if SplashTop only wakes from "suspended" or not but true wake on lan does not mean that at all. The PC is off as far as any OS is concerned. The support is usually on the motherboard and once that "magic packet" is sent via ethernet--or WiFi if it supports wake on wireless--then that PC computer comes to life. Does not have to be in suspend or hibernate. Aside from listening on ethernet or wifi is is off.
But again, I am not sure what the SplashTop support for this is. But if they say wake on lan I would assume it doesn't just mean wake from standbye.
Michael
I'm not an expert on this but doesn't your PC have too support a true wake on LAN? I haven't seen any iPad/iPhone app including splashtop that supports a true wake from completely off.... It just works to wake it from sleep.
Everything is Bigger in TEXAS!!iPad 16GB WiFi
iPhone4 32GB
Be sure and check out iphone4forum.net! For anything iPhone..
Me over on the other side...
It has to be supported in the computer's BIOS firmware, but it's been years since I've seen a computer that didn't have the option. According to Splashtop's web site, it fully supports WoL by sending a packet to computer that's off, suspended, or in hibernation, which I didn't know (and will never use).
You had your entire life to prepare for today.
OK I checked into SplashTop's implementation of wake on LAN. It is pretty much a separate function... similar to other iOS out there dedicated to wake on LAN.
As I suspected it only works when on the local network. You have to have already connected to the PC--it must save the MAC address transparently after you have connected once.
It won't work over the Internet though most dedicated apps won't either.
But in other news the Splashtop server and app were just updated. Now supports native PC resolutions and not just 1024*768 and 800*600. And finally pinch and zoom! Yay!
Michael
I can vouch for LogMeIn's Wake-on-lan working perfectly happily over the internet.
But I am only here hoping to find a way of controlling an iPad from my PC (or a Mac) - so as to help an elderly relative from afar.
Rod
