Any way to force a WiFi connection?
This is a discussion on Any way to force a WiFi connection? within the iPad General Discussions forums, part of the Apple iPad Discussions category; I have had this happen every once in a while, when attempting to open Safari, it just indicates the iPad is not connected to the ...
Results 1 to 5 of 5
    7065
    Jun 2010
    Northern ma
    6
    I have had this happen every once in a while, when attempting to open Safari, it just indicates the iPad is not connected to the internet. I can't find a way to force a connect. Sometimes it pops up and has me type in the security code, and when that happens, I always get connected.
    What causes this loop I seem to occasionally get stuck in? I'm in that situation know, so had to jump on my PC to post this.
    Thanks!
    iPad Ninja
    3495
    27 times
    May 2010
    Switzerland
    2,017
    Did you check to see if you're on the latest iOS (3.2.2)? That contains some bug fixes. Now, that being said, I think that there are still some bugs in the WiFi code because I occasionally have the same problem.
    A quick fix is to turn WiFi off and then back on again in settings.
    7065
    Jun 2010
    Northern ma
    6
    How do you download the latest OS - I have an older version.
    17419
    2 times
    Oct 2010
    Texas
    646
    Just D/L iTunes plug in your iPad and you should see the check for update button.
    Everything is Bigger in TEXAS!!
    iPad 16GB WiFi
    iPhone4 32GB
    Be sure and check out iphone4forum.net! For anything iPhone..
    Me over on the other side...
    7065
    Jun 2010
    Northern ma
    6
    Thanks all - I know have 3.2.2 loaded. Let's see if it goes better with the WiFi with the updated OS.
  1. Wifi connection slow and unpredictable
    By DMad in forum iPad Help
    Last Post: 12-15-2010, 01:34 PM
  2. Replies: 3
  3. Keep losing wifi connection
    By Dpeach in forum iPad Carriers
    Last Post: 06-29-2010, 06:28 AM
  4. Wifi connection drops solution!
    By Itzxdjx in forum iPad General Discussions
    Last Post: 04-18-2010, 01:17 PM
  5. Has anybody else been having intermittency with WiFi connection?
    By djpritchard in forum iPad General Discussions
    Last Post: 04-10-2010, 03:47 PM
force connect to wifi
force connect wifi
force connect wifi ipad
force ipad to connect to wifi
force iphone join wireless
force itunes to find iphone wifi
force wifi connection
how to force a wifi connection
how to force connect to wifi
how to force ipad on one wifi connection
how to force wifi
wifi force connect
