Belkin Bluetooth receiver - alternatives WITH volume control?
This is a discussion on Belkin Bluetooth receiver - alternatives WITH volume control? within the iPad General Discussions forums, part of the Apple iPad Discussions category; Hi Is there a Bluetooth receiver like the Belkin, but one that lets you control the volume from the iPad, without jailbreaking or beta software?...
Results 1 to 8 of 8
    6858
    Jun 2010
    Canada
    291
    Hi
    iPad Enthusiast!
    10166
    Jul 2010
    31
    Quote Originally Posted by Stefx View Post
    Hi
    Is there a Bluetooth receiver like the Belkin, but one that lets you control the volume from the iPad?
    Yes, it's called the Belkin Bluetooth receiver. Airplay allows the iPad to control the volume.
    6858
    Jun 2010
    Canada
    291
    FYI the Belkin Bluetooth receiver does not let you control the volume from the iPad (it outputs a non-variable line level audio signal), and I'm not looking for a new Airplay-enabled amp or an iHome.
    iPad Enthusiast!
    10166
    Jul 2010
    31
    FYI the Belkin Bluetooth receiver does not let you control the volume from the iPad (it outputs a non-variable line level audio signal), and I'm not looking for a new Airplay-enabled amp or an iHOme.
    FYI mine does. I'm sure you read this but I'll repeat it for others.
    "I have the Belkin Bluetooth and it allows you to adjust volume on the iPad (at least with ios 4.2 and Airplay). Airplay is kind of interesting. When you open Airplay on the iPad, you can select to send the audio to the Apple TV, the Belkin Bluetooth, or the iPad speaker."
    It's less than $40 and will feed any powered speaker or an amp. However, with an amp, the Apple TV 2 is much more versatile.
    6858
    Jun 2010
    Canada
    291
    thanks, I edited my question to specify no jailbreak or beta software.
    6858
    Jun 2010
    Canada
    291
    Update...
    With iOS the official iOS 4.2.1 the bluetooth is now variable audio out. Volume control on the iPad works with the Belkin bluetooth receiver.
    iPad Junkie!
    8982
    Jul 2010
    Canada
    157
    But how does it sound? as good as a wire?
    6858
    Jun 2010
    Canada
    291
    Nope, not as good as wire, but better than those old FM transmitters used in cards to send an ipod's sound to a car's audio that did not have an aux in
  1. Problem with volume (down) control
    By jmarkhenrik in forum iPad General Discussions
    Last Post: 03-17-2013, 07:14 PM
  2. Sound volume control
    By TFarmer in forum iPad General Discussions
    Last Post: 10-07-2010, 05:10 PM
  3. No volume control while ipad is docked
    By Matenrou in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-28-2010, 02:23 PM
  4. volume control for external microphone
    By old shep in forum iPad Help
    Last Post: 09-24-2010, 04:44 AM
  5. Volume control on bluetooth headphones (hardware or software)?
    By brobar in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-16-2010, 05:21 PM
belkin bluetooth alternative
bluetooth adapter denon forum
bluetooth adapter for denon receiver
bluetooth line level audio
bluetooth receiver for ipad
bluetooth receiver volume control
bluetooth receiver with controls
bluetooth receiver with volume adjustable
bluetooth receiver with volume control
denon bluetooth adapter
denon bluetooth receiver
denon n5010 bluetooth adapter
