Locked out twice!!! How do I fix?
This is a discussion on Locked out twice!!! How do I fix? within the iPad General Discussions forums, part of the Apple iPad Discussions category; No idea why this keeps happening, because I have not set up a password lock for my Ipad, but twice over the past day when ...
Results 1 to 9 of 9
    1997
    Apr 2010
    8
    No idea why this keeps happening, because I have not set up a password lock for my Ipad, but twice over the past day when I turn the device off using the switch on the top right, I come back to the screen asking me to enter a password after I swipe my finger to unlock. Yesterday I had to run a "restore" out of Itunes to fix the problem, and I do not want to do that again.
    Why is this happening and how do I fix the problem? My Ipad is unusable.
    1798
    Mar 2010
    Louisville, KY
    2 ideas
    1. You are having it sync to Exchange and Activesync is forcing a policy to force a password
    2. Something has turned on Auto-Lock under Settings - General
    If you run a restore it puts everything back including the password....
    1997
    Apr 2010
    8
    Quote Originally Posted by digriz View Post
    2 ideas
    In regards to point #1, I am syncing with Exchange, but I've been getting mail for hours without a problem. I also receive mail to the Blackberry Enterprise Server. If Activesync was forcing a policy, wouldn't I be getting locked out every time my email tries to sync?
    In regards to point #2, I've looked at my settings and no password has been set, nor have I previously set one.
    It seems that this only happens after I hit the on/off/sleep button on the top right of the device (though admittedly, it doesn't happen every time, so it may be coincidence). Anyway, how do I go about troubleshooting? I called Apple and their agents seem absolutely clueless.
    I was told to try to use the "transfer" button in Itunes when the password lock came up, but when I did that, the screen just toggled on for a brief flicker, then turned off. Nothing transferred. How do I ensure that if this happens again, I don't lose all my apps, and more importantly, all the settings that I've spent hours calibrating within the apps?
    1997
    Apr 2010
    8
    2 ideas
    Okay, I think you are onto something actually. I went to my Exchange account on my Ipad and turned SSL off, it then prompted me to enter a new password and confirm it. I did so, then immediately hit the on/off/sleep button. I then immediately hit the on/off/sleep button again and it prompted me to enter a password. The password that worked was the one I just entered for the Exchange account. So, my next question is, why does it only ask me to enter a password after I hit the on/off/sleep button? Is there any way to make it stop asking for a password altogether?
    1939
    Apr 2010
    Reno, NV
    22
    Take it back. Ask a Genius.
    1798
    Mar 2010
    Louisville, KY
    Mine is also activated against Exchange. When I activated it with ssl enabled of course. It prompted me for a password. I put in a standard numeric password.
    Pretty sure, It locks immediately after you hit the top switch even if you have been using it. That is working by design and activesync policy
    Might want to check this setting
    If you go into the Passcode Lock screen.
    There is an option, Require Passcode that can be set to immediately, after 1 minute, after 5 minute, or after 15 minutes.
    121258
    Nov 2011
    Florida
    Lightbulb Thanks for the help
    Updated the ipad software to ios5 and finally finished reloading all the apps and configuring Exchange. I went to bed and this morning the ipad asked for my password when i turned it on. I put in my regular 4-digit numerical unlock code and nothing. After trying my itunes password and every other password, i was locked out for 5 minutes, then 15 minutes then 60 minutes.
    Fearing that my iPad was about to be turned into a brick, i stopped by here and as soon as i saw "Exchange" I figured that must be the password that this thing is looking for. Entered it and viola... Thanks
    124716
    Nov 2011
    Oklahoma
    Quote Originally Posted by alybrenston View Post
    Okay, same thing here, woke up to a pw screen and had keyboard instead of number pad. My password for Exchange is not working either though.
    Any way to disable or restore it without?
    124716
    Nov 2011
    Oklahoma
    Quote Originally Posted by Todd83 View Post
    Never mind, I'm an idiot. Forgot I had this one synched with different account....
i locked myself out of my ipad
ipad 2 locked out
ipad lock out
ipad locked out
ipad locked out password
ipad locked out reset
ipad passcode lock out
ipad passcode locked out
lock out of ipad
locked out of ipad
locked out of my ipad
my ipad is locked
