My iPad keeps using 3G instead of WiFi
This is a discussion on My iPad keeps using 3G instead of WiFi within the iPad General Discussions forums, part of the Apple iPad Discussions category; Normally, if I select a WiFi network, mi iPad connects to it and not to 3G. Sometimes, however, it does not seem to do so. ...
Results 1 to 3 of 3
    19049
    Oct 2010
    For example, right now as I write, I am sitting next to my home's WiFi modem, which is readily recognized and shows up in "Settings" as having a strong signal. I keep selecting my WiFi network, the tick or check symbol appears next to it as if the iPad had acknowledged I selected it, but the 3G legend persists in the upper left corner of the screen.
    This happens from time to time and I don't k ow what to do.
    It also happened once in an airport at another city
    It was a source of concern because I didn't want to be charged for roaming, when there was a strong WiFi signal available at the place.
    Your advice is appreciated.
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    Delete the WiFi connection, then set it up again. This has worked for me and many others. Also a reboot sometimes helps.
    Good Luck
    Pocobear
    12183
    Aug 2010
    Detroit
    21
    I had a similar situation. Now I leave the cellular data setting off unless I need it because I unintentionally exceeded my 250MB limit.
    chesterhound
    Apple iPad 1 32GB + 3G
    MacBook Pro
    iPhone 3GS
  1. how turn wifi OFF/ON without the need to reenter wifi password
    By lse123 in forum iPad General Discussions
    Last Post: 07-08-2010, 11:06 PM
  2. Sold my 16gb wifi and wait for 32gb wifi is killing me
    By Ian B in forum iPad General Discussions
    Last Post: 06-29-2010, 06:19 PM
  3. Setting up Verizon Blackberry Tour Wifi Hotspot for Ipad Wifi
    By xlr8nflorida in forum iPad General Discussions
    Last Post: 06-14-2010, 11:09 PM
  4. Wifi vs 3G wifi speed/reception
    By CPMS in forum iPad General Discussions
    Last Post: 05-03-2010, 10:25 AM
  5. WiFi VS. WiFi + 3G WiFi Issues
    Last Post: 05-01-2010, 12:26 PM
ipad keeps on 3g instead of wifi
ipad keeps switching from wifi to 3g
ipad keeps switching to 3g
ipad use wifi instead of 3g
ipad using 3g instead of wifi
ipad using wifi instead of 3g
iphone keeps switching to 3g
is my ipad using 3g or wifi
why does my ipad keep going to 3g instead of staying on wifi
why does my ipad keep switching to 3g
why does my ipad keep switching to 3g from wifi
why is my iphone using 3g instead of wifi
