Unit won't charge from wall outlet
This is a discussion on Unit won't charge from wall outlet within the iPad General Discussions forums, part of the Apple iPad Discussions category; Unit just about six weeks old. Never dropped or abused. Last night before bed time plugged in and in morning still at about 28%. Did ...
Results 1 to 8 of 8
    14779
    Sep 2010
    daytona beach fl
    130
    Unit just about six weeks old. Never dropped or abused. Last night before bed time plugged in and in morning still at about 28%. Did a full reboot (white apple appears) and when unit comes back up it says not charging. Pull the module and reinsert in wall outlet. No message, just the indicator at top that continues to show .... now 27%. Any help out there? My wife has offered to get me the "T" shirt that says "Murphy" on the front of it. Sure seems to apply to me
    Jerry
    15357
    Sep 2010
    Germany
    102
    Are you sure you used the correct power-supply?
    From the outside, the power-supply of the iPhone 3G / 3GS looks identical to that of the iPad but doesn't have enough power for charging it.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    Well someone has to ask these questions...
    When your iPad is plugged into the power cube, do you see the lightning bolt where the battery is?
    If not, then you have:
    a) A defective docking cable.
    b) A defective power supply.
    or
    c) A defective iPad.
    14779
    Sep 2010
    daytona beach fl
    130
    Don't have the iphone referenced, so, that's not the problem. I have two of the white power cable modules (one came with my iPod) and tried both. They (USB) plug into the larger white module which plugs into the wall outlet. No lightning bolt shown ... only the battery icon with 27% in front of it and the battery icon showing a small area of white as to the amount of charge it has.
    Any way of checking the module that plugs into the wall?
    If the iPad itself has to be replaced, what is the recommended procedure for backing it up now before the battery goes completely dead?
    Jerry
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    Assuming the docking cable is good, you can just go into iTunes and sync. The first thing it will do is perform a backup.
    You will know right away if the cable is good or not because if it is bad, your iPad won't show up in iTunes.
    But as long as you are going to plug your iPad into your computer anyway, if your iPad shows Not Charging, that's actually a good thing!
    It means that your computer is connected to your iPad and it actually is charging it, but very slowly. If this is the case, that means your charger is bad. If you do not see the Not Charging message, that can still mean the cable could be bad or the iPad itself could be bad.
    I think Wal-Mart sells cables. That is the most likely thing to break so that is what I would try first.
    14779
    Sep 2010
    daytona beach fl
    130
    Neither of the two identical cables will allow the iPad and iTunes to talk o each other. So they are not seeing each other.
    That means no way to back up my setup on the device. My data is secure, thankfully as I have it all backed up. I was just thinking of the pain of having to restructure the device. I purchased it at Best Buy exactly a month ago and paid for full warranty. In such a short time, however, I don't know if it would be Apple or Best Buy who care for any replacement or repair. Or how long to be without the device.
    I wanted to use it in teaching a special class coming up in two weeks, but it looks like that is out the window now!
    JB
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    Well I am at a loss since everything points to the iPad at this point since it is unlikely that you have 2 bad cables. Sorry.
    iPad Junkie!
    15982
    Sep 2010
    NH
    154
    Easy way to check power adapter is just plug another usb device into it and see if it works, but if your computer is not seeing it, sounds like Ipad issue.
  1. Replies: 41
    Last Post: 04-27-2010, 07:06 PM
  2. wireless folding travel keyboard unit for the ipad
    By henry2 in forum iPad General Discussions
    Last Post: 04-06-2010, 08:47 PM
  3. ipad and it basic apps for the unit and the accessoies for it
    Last Post: 03-29-2010, 12:18 AM
ipad not charging wall plug
ipad not charging when plugged into outlet
ipad not charging when plugged into wall
ipad won't charge
ipad won't charge in wall outlet
ipad won't charge when plugged in
ipad won't charge when plugged into wall
my ipad won't charge when i plug it in
